'61 Dynamic 88 wagon fuel tank
Old Apr 18, 2023 | 12:11 PM
BudL's Avatar
I have a '61 Dynamic 88 wagon with an LS (LQ4) engine. I would like to install an in tank fuel pump to replace the frame rail mounted pump. Does anyone know of an aftermarket setup that will work with this tank or an aftermarket tank that is built to accommodate an in tank pump? Thanks
Old Apr 19, 2023 | 09:55 AM
Fred Kiehl's Avatar
There are a number of in tank pump systems that will fit. You may find clearance issues on the top of the tank with an in-tank pump mount. There is nothing wrong with a frame mounted pump, as long as it is mounted low, and has adequate cooling. You may even find that the external pump has some benefits in that you will not have to drop the tank if you need to replace it. Unless you have a problem with fuel scavenging, I would keep the exterior pump.
LuckyLuke
19
Nov 27, 2021 09:21 AM
dynamic88builder
Sep 10, 2021 12:42 PM
krauser65
Dec 26, 2018 09:08 PM
SkyBlueRacing
Aug 14, 2017 07:44 AM
joca
Aug 13, 2016 08:46 AM
