Closest replacement fuel tank 61-64 olds 88
Old August 10th, 2016, 04:41 AM
joca's Avatar
Hi everyone I'm new here although not new to Oldsmobile.
My 61 olds holiday 88 coupe needs a new fuel tank or one off another car that is close and can be made to fit.
From the research Ive done thay don't reproduce this tank. Any ideas would be appreciated the 61-64 Impala tank looks close but doesn't have the indent for the axle. Sending unit is different also.
My original tank is a complete mess its rusty and the previous owner tried sealing it with those epoxy kits that is flaking off on the inside.
thanks in advance
joca is offline
Old August 10th, 2016, 06:18 AM
I don't know if a Chevy, Pontiac, Buick or Cadillac tank from the same years would fit. It would probably be easier to use an aftermarket tank.
Olds64 is offline
Old August 10th, 2016, 11:05 PM
joca's Avatar
Thanks for the reply the only tank that is somewhat similar is a 61-64 Impala but I don't think this will clear the differential. Aftermarket not sure only a fuel cell but don't want to install inside the trunk.
Just hoping some other Olds owners have adapted something that looks somewhat factory.
joca is offline
Old August 11th, 2016, 05:47 AM
Phantom Phixer
Charlie Jones's Avatar
The Olds parts book says that all 61 and 62 tanks are the same , except F-85 and station wagon .
This may broaden your search for a used tank.
Charlie Jones is online now
Old August 11th, 2016, 07:12 AM
Proud Viet Nam Veteran
redoldsman's Avatar
These guys don't have one listed but I would give them a call. They are good folks and might give you some idea.
http://www.tanksinc.com/index.cfm/pa...=cat/cat59.htm
redoldsman is offline
Old August 11th, 2016, 12:31 PM
D. Yaros's Avatar
https://classicoldsmobile.com/forums...-starfire.html
There is a guy right here parting out a 63 SF. Will that tank work?
D. Yaros is offline
Old August 12th, 2016, 03:10 AM
joca's Avatar
Hi thanks for the replies living in Australia doesn't help, but I can get a tank shipped here.
I really want to get something new not used another option is to cut mine in half clean out the flaking sealer and rust and and then weld it back together and reseal it but this is a lot of work. Also the tank has baffles welded on the inside which is another issue.
I will email Tanks see if they know of something similar to my Olds tank. Thanks
joca is offline
Old August 12th, 2016, 03:16 AM
joca's Avatar
Hi thanks for the replies I really want a new tank living in Australia doesn't help but I can get a tank shipped here.
I will contact Tanks see if they can recommend something.
Another option I have is cut my tank in half clean up the flaking sealer and rust and then weld it back together. Another problem with this is the tank has baffles welded on the inside.
Life is so much easier for our Chevy friends.
joca is offline
Old August 13th, 2016, 08:46 AM
Larry/car's Avatar
I would search for a car that is being parted out. Should be a clean used tank somewhere? (rust would be my concern) If all options are exhausted, using your old tank as a guide, thinking a tank could be fabricated. A custom made tank would not be cheap.
Larry/car is offline
dfire25
June 28th, 2016 01:37 PM
Warren Seale
February 19th, 2014 08:23 AM
67442nut
October 20th, 2013 03:02 PM
1972 Hurst Olds
October 7th, 2012 10:45 AM
71Oldsmobile
May 5th, 2012 07:08 AM
Quick Reply: Closest replacement fuel tank 61-64 olds 88
