324 Engine Bolt Specs
Old January 26th, 2014, 11:43 AM
Olds Scott's Avatar
Coming in on the home stretch on my 324 build but the last owner of my 55 tore the top end off the engine and lost the intake and exhaust bolts. If anyone out there would know the bolt sizes and lengths it would save me some time. I already have the thick washers. Thanks for any help.
Olds Scott is offline
Old January 26th, 2014, 02:19 PM
2blu442's Avatar
Hi Scott
I pulled the top end of my parts car 324 last summer. I included most of the intake fasteners when I sold the intake. But there were two intake studs and four exhaust studs still in the heads. Also a baggie that I think were exhaust fasteners I pulled last summer. I used the vice grips and got the studs out of the heads. The two intake ones look like they're maybe two threads longer than the exhaust studs. Here's some pictures. If it would help I'd send you the bolts/studs in the photos below for $10 to your door. Let me know what you think. John
2blu442 is offline
Old January 26th, 2014, 03:41 PM
Phantom Phixer
Charlie Jones's Avatar
Smile
According to my 49-63 Olds parts book the following parts to fit 54-56 Olds are listed in group 3.275 STUD-NUT-BOLT-WASHER, MANIFOLD ATTACHING
STUD (3/8 X 2" overall) #554191 4 used per car
STUD (3/8 X 1 25/32) #581980 8 " " "
BOLT (exh. manifold to cyl. head "special seez pruf") #557903 4 per car (no size given)
BOLT (intake manifold to cyl. head) 3/8'-16 X 1 1/4" special head) #564863 1 per car (maybe more?)
NUT (3/8"-24 special seez pruf) #3679216 as required
WASHER mfld. clamp 1/4" X 1 3/8" #400130 4 per car
WASHER mfld clamp 1/8' X 13/16" #555698 as required
Hope this helps.
Charlie Jones is offline
Old January 26th, 2014, 06:32 PM
Olds Scott's Avatar
Thank you gentlemen for all your help, between 2blu442 pictures and Charlie Jones list I am on my way to my intake and exhaust manifolds.
Old January 27th, 2014, 05:32 AM
Rocketowner's Avatar
Scott,if you purchase the bolts above an easy way to remove the rust is to put them in a plastic container and cover them with white vinegar.Leave them 24 hrs,then rinse and dry and coat with a light coat of oil. This worked for me on a rusty chain I had. Larry
Rocketowner is offline
kirkwoodken
Tech Editor's Desk
26
December 24th, 2023 06:59 PM
sweet56olds
February 21st, 2015 09:34 PM
Boilerz25
August 6th, 2014 07:42 PM
Danny Boy
August 25th, 2010 07:39 AM
mr-tom
July 29th, 2007 04:26 PM
Quick Reply: 324 Engine Bolt Specs
