Removing chrome trim on 55 dash
Old September 11th, 2021, 02:14 PM
Dave’s Holiday 55's Avatar
OK. Bought this car thinking everything would be working like new from the factory. How naive was that. So far I’ve had to fix or replace the heater fan motor, the windshield wiper motor, the fresh air vent cables, a window crank clip, wheel spinners, the clock, and the radio and power supply. Right now working on the radio install. Removed the after market radio the previous owner had installed in the glove box and the Radio Shack speaker. The power supply was completely missing. I just feel that the radio power supply and speaker would be easier to replace if the chrome trim was out of the way. I can’t figure out how to get it loose. The trim over the radio was held on with two nuts and bolts but the trim over the speaker has some threaded studs but no nuts. It doesn’t seem to want to pop off like it was held with spring clips. Anybody done this little job? And by the way, what are those two rectangular shiny silvery boxes mounted behind the trim to the left and right of the speaker?
Dave’s Holiday 55 is offline
Old September 12th, 2021, 04:33 AM
WHIPOLDS's Avatar
Those two boxes would be the ash trays. They should have a light inside.
Rick
WHIPOLDS is offline
Old September 12th, 2021, 05:21 AM
No. Not the ashtrays. I removed those, and the boxes they fit in, when I was taking the radio out. The shiny silver boxes I’m talking about are behind the chrome trim immediately beside the speaker grill. You have to slide underneath the dash and look back up to see them. Or, as I discovered after contorting my aged body, you can hold a mirror and a light source under the dash and see these two rectangular boxes. It looks like they have a cover on them held on with a couple screws. I am hesitant to open them up to see what they are without having some idea of what I will find.
Old September 15th, 2021, 07:55 AM
Tedd Thompson's Avatar
I don't remember those boxes that you speak of, and I have spent my share of time under the dash. How about a picture and maybe that will jog my memory..... Tedd
Tedd Thompson is offline
Old September 15th, 2021, 12:31 PM
Old September 15th, 2021, 12:33 PM
The first picture is the one on the right side and, obviously, the second picture is the left. Does this help?
Old September 15th, 2021, 06:58 PM
Pat55Olds's Avatar
Dave you don't need to remove these, they are parts of the "design" trim that goes around the clock
Just remove the 6 screws as marked on the pict.
Pat55Olds is offline
Old September 15th, 2021, 08:09 PM
OK. Thanks for all the help. I believe all of my new and repaired parts will be in my hands by the end of the week. It’s anybody’s guess as to how quickly the new and repaired parts will be in the car. Probably not by the end of the week.
Old September 16th, 2021, 07:09 AM
Collector of Stray 55's
Olds Dad's Avatar
Pretty sure that those are just part of the dash trim casting for the recess on the front side - there's nothing inside them
Olds Dad is offline
TomT
July 4th, 2017 06:28 PM
DFitz
June 3rd, 2015 01:02 AM
JpMotorsports
October 26th, 2013 10:50 PM
webby
April 22nd, 2012 07:08 AM
dingusboy
May 14th, 2009 05:14 AM
Quick Reply: Removing chrome trim on 55 dash
