55 olds 98 passenger side air box removal
Old Jan 1, 2021 | 01:46 PM
dahl1car's Avatar
What holds the out side box on after screws are removed. Is there something inside holding it also.
Old Jan 1, 2021 | 03:02 PM
ignachuck's Avatar
Frank Ignachuck
the "outside air box" is held on by an awful stuff known as "goop" for lack of a more technical term. You will have to gingerly pry that off and It will not be easy. The more important question is "why do you want to remove it"?
Old Jan 1, 2021 | 04:23 PM
dahl1car's Avatar
I'm doing a frame off paint i need to clean up the firewall and every thing else.
Old Jan 1, 2021 | 04:27 PM
dahl1car's Avatar
The air box im talking about is the fan motor box .
Old Jan 2, 2021 | 07:41 AM
Tedd Thompson's Avatar
Use a heat gun to soften up the goop. They are sometimes a bitch to get off around the radiator core from inside the interior air box some times needs to be heated up to get to the goop it gets like cement after a half a century or more....Tedd
Old Jan 2, 2021 | 04:41 PM
dahl1car's Avatar
dahl1car
Thanks for the reply & information I finally got it off. You were right it was stuck on.
55ash
Jun 28, 2013 11:54 AM
Erinyes
Jun 9, 2012 09:05 AM
501Paratrooper
Jun 8, 2012 08:24 AM
dennisspeaks
Sep 28, 2011 07:17 PM
Dreamworks
Suspension & Handling
Oct 21, 2010 07:58 AM
