Door window questions!
Anyone know which (if any) window regulator and channel parts from the tri-five Chevrolets are the same/similar enough to use, as the '56 Olds parts? In particular, the channel under my window glasses (four door) need replacing. These are the channels that the felts sit in, and that are screwed to the tracks that the rollers fit in. Thanks!
Doubtful Tri five will work but 2blu442 on this site has a 55 four door he is parting out he may be able to help out. If someone here with a Hollander could look up the part number and see if it is the same for a 55 and 56 that would take the mystery out of it.... Tedd
