57 frame ?
Old August 15th, 2018, 11:10 AM
RocketRonnie's Avatar
57 frame ?
Hope everyone is good.
So, i have some questions regarding Oldsmobiles of the 50"s and older in general. Did any use the torque tube that Buick used?
what are the pros and cons of the x frame?
Whats needed to put in a th400, bbo 425, 455 or sbo 350 in these cars?.
the car im looking at is a super 88 4 door 1957.
thanks
RocketRonnie is offline
Old August 15th, 2018, 04:13 PM
Tedd Thompson's Avatar
As Far as torque tubes go no mid fifties Old's used a torque tube.I believe even during the Hydra-matic shortage when Buick Dinda-flow's were used on a few cars they still had a the regular drive line configuration.
Nothing wrong with a X frame except it makes it hard to work (remove) the pan compared to a ladder designed frame. They are heavy and hell for stout though.
What's needed for a swap is mostly a lot of money,it has all been done before, lots of room to work with. Not my cup of tea but it's not my car or money either.... Tedd
Tedd Thompson is offline
Old August 15th, 2018, 06:25 PM
Thanks Tedd, good news about the tube and frame. Where does most the money go to make the swap possible?
Old August 16th, 2018, 08:35 AM
Usually in someone else pocket is where most of it goes unless you have good fabrication skills. You will need to make (fab) a rear cross member for the transmission and some kind of front motor mount system. I have heard of people who use / adapt a Toranado front motor mount to the front mount of the 371 and get by instead of side mounts.
You will need to have a different drive line made and it's doubtful if your 4 door came with a limited slip diff (very rare in 57) so a a different rear end will need to be sourced unless you keep it a peg leg.
Tons of small stuff like radiators, electric wiring, exhaust system, probably shocks and suspension changes. and of course brakes and master cylinder change. More but I can't think of them now.
If mine I would and I was to do this on the cheap I would spend most of my money on the original engine and transmission rebuild, maybe add a cam and J2 setup for bling and a extra 30 HP. Make it safe and add some cool wheels and a good paint job and just drive the Old Girl and let people admire it as it was 60 years ago.The thing weighs over 4500 pounds it will never be a real hot rod, though quicker than what it was stock that weight is hard to over come.Plus every time you put a cutting torch to it it devalues the car even more. You will never get your money back out of a engine swap on a 4 door 60 year old car. You might on a original kept car (probably not though)..... Just my thoughts and as you can tell I a fan of unmolested cars but I feel my points are legitimate at least for me. Best of luck what ever you do.... Tedd
Old August 16th, 2018, 09:20 AM
thanks for knocking some sence into me. I appricate it, i have some space to pick up another car and a little money put aside so its like trying to figure out were to go on vacation.
i can pick up said 57 with no engine for 1000.
a 61 dynamic 88 ht that needs all the interior done and looks bad for 2200.
a 68 olds 98 convertible that needs alot plus some windows and windshield for 700$.
a Buick 2 door ht electra (like a 98) that runs with good interior for 1200.
or (this one will hurt the pocket more) a 39 buick buisness coupe with an olds v8 that is a project.
i really want a bubble top but it just might not be a good time for me seeing as how parts for it cost so much.
Old August 16th, 2018, 10:50 AM
All of them come with issues that are expensive to over come. The 57 needs a engine that is hard to source and has a transmission that will only bolt up to a first generation Old's engine.
The 61 needs expensive interior, has a transmission that was problematic from the get go and no one likes to work on besides.
The 68 convertible sounds interesting but restoring a 98 convertible is not for the light of heart. There are no sheet metal or most everything else aftermarket parts made of a 98 and especially a convertible. The beginning cost doesn't mean much if you can't find parts and rust can be a issue with old convertibles with leaky tops.
The 39 would be worth a look depending on how bad or good everything was put together. Lots of fab work hard to get parts but a cool ride if you ever finished it. What year engine and transmission was used? Makes a difference in cost of engine and transmission parts if it was first generation or a later combo. Nothing is cheap on a 70 year car.
The best advice I can come up with would be to hold off a while save your money and keep a eye out for a deal that doesn't need so much work, they are out there. You Just have to wait for one of the four D's to happen, you know the four D's. death, divorce, debt and desire that always creates a quick sale for a good price...... Just my observations from doing this for a few years. All this information is worth exactly what you paid for it and probably worth less...... Tedd
Old August 16th, 2018, 11:19 AM
For got to mention the electra is a 66.
super solid advice Tedd hope you have a greatday
Erik Andersen
October 3rd, 2016 06:00 AM
cupo
June 30th, 2015 08:42 AM
keithnh
October 30th, 2011 02:14 PM
blood sweat and oil
March 19th, 2009 08:43 AM
Joel n
November 19th, 2007 01:48 PM
Quick Reply: 57 frame ?
