Wiper motor information vacuum to electric
Well ladies and gents I have spent the last three hours trying to adapt a Chevy electric wiper motor to my 55 Olds and the conclusion is, it can be done, but not by me at this time.The mounting holes line up but the transmission connectors are off by a little more than a 3/4 inch so the mounting holes need to be moved up that 3/4 inch requiring a cut and re weld.Not a problem when I had a shop but not possible now. Also the Chevy motor will set very close to the bat-wing, so close that my tape measure says they will rub. If this was the only option I would work my way through it but it's not so I'm off to purchase a wiper conversion motor and I will let you know how that works out.....Tedd
A member with a very impressive 1956 black & white 98 recommended New Port Engineering. I looked up their site and bookmarked it.
https://www.newportwipers.com/index.php
Let us know as I will soon be doing the same thing on my 55.
Rick
Washer jar
pick,
It's a glass jar and can be purchased from Fusick. part #WWJ508. You will also need a mounting fixture, jar lid and pump.I don't know of any aftermarket mounting fixtures or complete pumps (someone chime in here if you know of any). so it's Ebay or a parts car for them. Lids are made after market and Fusick number is WJC507....Tedd
I saw a nice jar/lid/pump go for around $75 on eBay recently, they come up time to time. Not sure if it had the mount though. That may be the hardest piece to find. My dad has a few washer units sitting in the garage, possibly complete and with the mount bracket, but it's a couple states away. He's not an Internet user, and I won't get back up there until 1-2 months. I'll check next trip and report back.
If you make the conversion to electric wipers, what do you do about the vacuum side of the fuel pump? I guess delete the lines and plug the ports on the pump. But couldn't you also get a pump for a newer model that had electric to start with and clean things up a bit?
Highwayman,
Or just use it( vacuum pump ) to operate the windshield wiper squirter's. It depends a lot on what look you want your car to look like and what you do with it . If you show your car in tough judged events by all means keep it as it was from the factory, If parking lot show and shines are your thing you can modify it and probably only the purest will know, or if you just want to keep the damn rain off your windshield and be safe going down the road, swap out what ever it takes to do that. It's your car and your money. Just remember a car seldom gets returned to it's original state so use your best logic and save your self some money down the road if you change your mind...Tedd
Vanguard83
February 6th, 2015 03:23 AM
Dan Wirth
March 18th, 2014 04:22 PM
Tedd Thompson
August 26th, 2012 05:59 AM
