Water pump difference AC vs non AC
Old Nov 4, 2025 | 04:58 AM
Mike16's Avatar
Can anybody state the difference between a standard waterpump and an AC waterpump on the early v8's
Thank you
Old Nov 4, 2025 | 05:36 AM
ub2693v's Avatar
I have a 55' with AC, on the 324, the bearing is different from the non-AC, more robust. As far as the impeller, mine originally had an aftermarket water pump with 8 vanes but the rebuilt OEM i received from Fusick has 6, although on ebay i've seen a mix of both 6 and 8 vane impellers on OEM water pumps for AC cars. I would imagine they beefed up the bearing due to the 6-blade radiator fan and dual belt pulleys, it moves a lot more air than the standard 4 blade, plus the ac cars have a shroud to help direct air into the radiator/condensor.
Old Nov 4, 2025 | 06:43 AM
Texas442's Avatar
1971 442 conv
Originally Posted by Mike16
Can anybody state the difference between a standard waterpump and an AC waterpump.
Thank you
Read this thread:
https://classicoldsmobile.com/forums...lengths-28191/
Old Nov 4, 2025 | 07:00 AM
Mike16's Avatar
Originally Posted by Texas442
thank you.
I was referring to the difference between ac and standard pumps on the 49 to 62 early v8's.
Old Nov 4, 2025 | 09:39 AM
mpolds's Avatar
Actually , the Non A.C. Water Pump fits 1949 - 1962….
The A.C. Water Pump fits 1953 - 1962 , as Olds didn’t have Air Conditioning until 1953….
I have both of them *** Brand New *** , but I would have to open
( frail “ rebuilt “ boxes ) to compare them side - by - side…..
Old Nov 5, 2025 | 10:26 AM
Mike16's Avatar
I'm curious about the rebuild kits used in the AC vs the non AC pumps. And what are any other differences that may exist in regards to dimensions.
Am I understanding correctly that ac pumps will not fit the 49 to 52 engines?
Can I use an ac Pump on my non ac car? Its a non ac 55.
Anybody ever compare the rebuild kits ac vs non ac?
is anybody aware of a part number for an ac pump rebuild kit and also a part number for an non ac waterpump?
Rustednutz
Jul 13, 2024 07:40 PM
72455
Feb 8, 2022 09:22 AM
lazy394
Jan 25, 2015 05:01 PM
coppercutlass
Nov 10, 2013 11:27 AM
silverriff
Jun 9, 2008 02:43 PM
