wow its been a few years .....but i followed OLdsDad lead ... had a few hic ups but this 2ton rocket now Stops on a dime .
little info ...
First had a guy in N california rebuilt my OE (Sunny) ...had it leak ! took it apart and not ALL SEALS REPLACED .
Frustrated , i followed OldsDad info.
here are pics :
JUNK FROM EBAY this is off a Malibu ....(dont recall the yr. early? 2010 Sorry ) Re drilled mounting holes Scarbird Kit Fit good ... A little fight but was able to use the original paddle . do recall re drilling the Brake Pad to the right to accept the push rod
little info ...
here are pics :
Do you still have the '57 that you put this power brake booster configuration onto?
It looks as though the brake pedal pushes directly against the master cylinder push rod with NO mechanical multiplication (leverage). In other words a one-to-one brake pedal to master cylinder piston ratio.
How has it worked out? Do you seem to have normal brake "pedal" and function?
Thanks!
That's where we're having issues... the mounting bolts on the Unversal booster are 3.375, and the brake master cyinder is 2.25, and they are 90 degrees offset. The booster wants the cylinder to be horizontal, the oritation on the cylinder needs to be vertical.
I've beeen scouring for a remote master cylinder that is 3.375 mounting and cannot find one. Been searching for a bosster that is 2.25 and cannot find one. This seems absurd... am I just doing the wrong searches ?
After much discussion we've basically just come to a "F IT" moment and have decided that we're going to build a bracket that will use the 3.375 holes vertically and provide some 2.25" holes for horizontal mount.... might have to lengthen the pushrod a lil bit.
