RPM at idle?
Old Nov 20, 2020 | 03:23 PM
maineolds's Avatar
RPM at idle?
Anyone know the stock spec for engine RPM at idle? I don't have a listing in my manual. I'm also having a hard time finding an open vacuum port on the intake manifold or carb. I need this to set the air/idle screws. I think I'll tap off the vacuum for the wipers. thoughts? Thanks
Old Nov 20, 2020 | 04:43 PM
The Magic 8 Ball is currently inoperative. Therefore, unable to assist w/o Model, Year, Engine size & Model/Manufacturer of carburetor.
Old Nov 20, 2020 | 04:45 PM
Unless it's been removed, look for the engine tune-up specifications label on the fan shroud. This car have AC?
Old Nov 20, 2020 | 04:49 PM
maineolds's Avatar
Thanks for the correction on missing info. I’ve made so many post on this car over the past couple weeks I thought I’d stated those details in this post but didn’t.
1949 Oldsmobile 88, Rochester carb. 6 volt. Other than the recent Petronix ignition, its stock. 29,000 original miles.
no data on any under hood tags
Old Nov 20, 2020 | 04:54 PM
I looked at your recent posts - you're the chap w/ the '49 88. Well, that one is going to be out of my league on idle specifications. Generally, that type information is contained in the tune-up section of the manuals, or directly in the front under the maintenance sections. Any vacuum should work fine for making the A/F mixture screws adjustment. Find a currently used vacuum line, and use a "T" fitting to tap into the vacuum line. I would think a rough estimate for idle would be somewhere in the ballpark of 850 rpm?
Old Nov 20, 2020 | 05:38 PM
rocketraider's Avatar
Oldsdruid
Back then very low idle speeds were seen as desirable. Like 400-450 rpm low. I'd start at 500-550 meself. See if you can find an old Motor's, Glenn's or Chilton's manual covering the 49.
Old Nov 21, 2020 | 09:06 AM
VC455's Avatar
Barely Registered
400 to 425 rpm per http://rocket100.com/olds-engine-spe...ocket-v8-spec/
Old Nov 21, 2020 | 09:13 AM
If you have a vacuum pump still disconnect and cap it while adjusting the carb.
Old Nov 21, 2020 | 03:53 PM
maineolds's Avatar
Great info. Thanks everyone
Old Nov 23, 2020 | 06:41 PM
maineolds's Avatar
Oldcutlass, should I also disconnect the vacuum line that goes to the choke and the vacuum line that goes to the distributor advance before setting the carb?
Arrowstorm
Jul 8, 2014 11:59 PM
AZ455
Mar 28, 2012 03:13 PM
steve walker
Dec 8, 2009 02:26 PM
Olds64
Aug 25, 2009 09:22 AM
Chumley
Aug 9, 2008 08:02 AM
