RPM at idle?
RPM at idle?
Anyone know the stock spec for engine RPM at idle? I don't have a listing in my manual. I'm also having a hard time finding an open vacuum port on the intake manifold or carb. I need this to set the air/idle screws. I think I'll tap off the vacuum for the wipers. thoughts? Thanks
Thanks for the correction on missing info. I’ve made so many post on this car over the past couple weeks I thought I’d stated those details in this post but didn’t.
1949 Oldsmobile 88, Rochester carb. 6 volt. Other than the recent Petronix ignition, its stock. 29,000 original miles.
no data on any under hood tags
I looked at your recent posts - you're the chap w/ the '49 88. Well, that one is going to be out of my league on idle specifications. Generally, that type information is contained in the tune-up section of the manuals, or directly in the front under the maintenance sections. Any vacuum should work fine for making the A/F mixture screws adjustment. Find a currently used vacuum line, and use a "T" fitting to tap into the vacuum line. I would think a rough estimate for idle would be somewhere in the ballpark of 850 rpm?
400 to 425 rpm per http://rocket100.com/olds-engine-spe...ocket-v8-spec/
