Power Steering Gearbox Lube
Old Apr 17, 2026 | 12:12 PM
madmax442.com's Avatar
madmax442.com
Mine is a 1955 power steering gearbox. What do I use to fill it? I just rebuilt the seals and need to fill it, it's empty.
Old Apr 19, 2026 | 07:08 PM
madmax442.com
Corn Head Grease, 90W, 90/140W? 81 views and no replies means no one knows I guess...? i certainly don't and have never had to fill a steering gear.
Old Apr 19, 2026 | 07:51 PM
Charlie Jones's Avatar
Phantom Phixer
Early power steering systems specified automatic transmission fluid type"A".
This has been replaced, in general use, by Dexron III.
Old Apr 20, 2026 | 03:23 AM
OLDSter Ralph's Avatar
Back in the 1960's, they actually sold "Power Steering Fluid" in cans. They were smaller cans for the same price as ATF. Most people figured out ATF worked and was half the price. Charlie Jones is correct.
Old Apr 20, 2026 | 07:25 AM
madmax442.com
Not the power steering pump and hydraulic system. the actual gearbox itself.
Old Apr 20, 2026 | 08:14 AM
Phantom Phixer
I believe these systems shared lubrication through the whole system.
That's why you must jack up the front wheels and cycle wheels from left to right when starting and filling a "dry" steering gear.
Check your 1955 Oldsmobile Shop Manual
I don't think power steering boxes ever took a separate lube.
Old Apr 20, 2026 | 08:16 AM
ub2693v's Avatar
I used 90w gear oil in mine a few years ago, the stuff that came out was black and looked like a mixture of grease and gear oil, real nasty stuff. Seems to be OK, no leaks and the steering is fine, I did read however that mixing the gear oil with "CV" joint black grease will make it less likely to leak over time.
Old Apr 20, 2026 | 08:21 AM
Phantom Phixer
Does your car have power steering?
Old Apr 20, 2026 | 08:25 AM
ub2693v's Avatar
yes, factory power steering
Old Apr 20, 2026 | 09:02 AM
madmax442.com
Hi Charlie, so yes it absolutely does. ATF and gear oil are separate and must not be cross-contaminated. The manual says fill gearbox with oil.
fill plug is right there. The control valve to the right is sealed off with orings and seals. Same with the power cylinder on the left. The pump, power cylinder, control valve and lines have ATF in them. The gearbox needs lube. I am leaning towards NLGI 0 or Corn Head Lube.
Old Apr 20, 2026 | 03:56 PM
Phantom Phixer
I see that this is different than the power steering gears used from the late fifties up that I am familiar with.
What does the service manual say about the lube to use?
What is "Corn Head Lube"?
Old Apr 20, 2026 | 04:29 PM
madmax442.com
They say its got the consistency of apple sauce. NLGI 0 flows more than a NLGI 2. Its like if you mixed chassis grease and 90W oil. I ordered a couple of tubes, it's what I came up with in my research. The service manual says on page 5-26, step 26, "Fill steering gear HOUSING with steering gear lubricant and install filler plug."
File Type: png
Old Apr 28, 2026 | 08:50 AM
madmax442.com
Topped it off a couple of times after I drove it, seems perfect, gearbox feels smooth. Now I have an extra tube of this that will sit in my garage until I die, LOL.
Old May 5, 2026 | 10:35 AM
madmax442.com
Roadie
Suspension & Handling
Nov 7, 2024 01:37 AM
Chuxter
Jun 30, 2024 04:51 PM
riskyb
May 22, 2022 06:53 AM
68442
May 18, 2022 07:37 AM
Reese Neis
Jul 4, 2021 01:03 PM
