Oil sending unit
Old Nov 7, 2023 | 06:25 AM
Super88chris's Avatar
Oil sending unit
Hey I have a 55 olds super 88. Does anyone know where to buy the sending unit and line that goes to the gauge because it seems like they are only electrical now. Is it possible to redo that little copper line?
Old Nov 7, 2023 | 07:00 AM
redoldsman's Avatar
Proud Viet Nam Veteran
You can probably use a compression fitting for a repair. I replaced the oil filter adapter on the 54 I had with one from a 63 so I could use a spin-on filter. It uses a different fitting than the 54 so I used a compression fitting to change it.
Old Nov 7, 2023 | 07:11 AM
ok, I’m kinda new to all this but what’s a compression fitting and where do I buy it? So that will make it so I can replace that metal line going to the gauge?
Old Nov 7, 2023 | 08:02 AM
redoldsman's Avatar
You should be able to find a 1/8" compression fitting at most auto parts stores. Here is what they look like.
Old Nov 7, 2023 | 09:03 AM
Oh ok great, I was just at autozone and I did see the copper tubing and fittings so that’s perfect. My gauge currently does work but it’s so old and brittle I just want to be prepared for if it goes especially since I’m swapping transmission and moving things around in that area.
Old Nov 7, 2023 | 01:44 PM
You can buy a copper tubing kit at your local autoparts store.
Old Nov 7, 2023 | 02:37 PM
redoldsman's Avatar
Now that I think about it, I think that is what I bought.
Old Nov 7, 2023 | 02:48 PM
Yeah I mean it looks right. I’m just wondering how the line goes into the sender and the gauge and doesn’t leak
Old Nov 7, 2023 | 02:56 PM
redoldsman's Avatar
The line should not be leaking where it goes into the gauge. Put your hand up under the dash on the back of the gauge and see there is any oil on the back of it. I doubt there will be.
Old Nov 7, 2023 | 03:41 PM
redoldsman's Avatar
It has a fitting on the end of the line that screws into the gauge. It has been there for 68 years and apparently has not leaked or you would have oil on your carpet. You are worrying about something you don't need to worry about. It is mechanical gauge. Quit worrying about it and enjoy your car.
Old Nov 7, 2023 | 05:45 PM
Dad-Par's Avatar
Hello Super88chris, A Classic Oldsmobile Member had a similar problem in a previous blog (I believe also with a ’55) and another member posted this link for this kit from Eckler’s. The member in need said it was what he was looking for (copper line and fittings). I don’t remember the specific Blog, but I figured it was important inf. to have avail so I saved (bookmarked) the website link. I have a ’54. Mine looks very similar. Hope this helps.
Ecklers Oil Pressure Gauge Line Kit, Small Block, 1956-1967
leftlaneonly
Hurst/Olds
May 3, 2021 11:31 AM
wherlehy
May 2, 2021 04:58 PM
69 Hurst
Apr 29, 2021 12:08 PM
yalikeme
Sep 4, 2015 12:25 PM
MN71W30
May 25, 2009 04:07 AM
