Newbie 49-50 Oldsmobile rocket 88
Old Aug 30, 2020 | 12:17 PM
Ducky's Avatar
Hello, I'm definitely a newbie and I acquired a 4950 Oldsmobile rocket 88 rat rod last year. I'm just starting to work through it, and this is where you get to find out how green I am, I can't find the brake fluid reservoir. I've been told it might be on the driver's side floor panel but there does not seem to be anything resembling a place to put oil in in that area.if anyone can point me on the right direction I would be greatly appreciative
Old Aug 30, 2020 | 04:57 PM
Charlie Jones's Avatar
Phantom Phixer
If you crawl under the car and look in the area of the brake pedal you will find the master cylinder .
It looks like someone bolted a patch on a rusted floor . Probably right over the access hole you're looking for .
This is an illlustration of a '56 , but it is a similar setup
Old Aug 30, 2020 | 06:59 PM
Tedd Thompson's Avatar
If I remember correctly it is possible to fill the master from the bottom using a small 1/4 inch plastic tube attached to a squeeze bottle but you can't see the fluid level. Otherwise you will need to open that access hole and fill it from the floorboard.... Tedd
Old Aug 31, 2020 | 04:41 AM
Beautiful Olds Ducky. Welcome to the site!
griffey57
Aug 5, 2020 07:31 AM
Jersey Jeff
Feb 7, 2018 11:23 AM
marc1964
Jan 21, 2017 12:20 PM
Wise Performance
May 13, 2013 06:16 AM
vintageabsinthe
Jan 26, 2010 04:20 PM
