Need help with vacuum lines on '56 Olds
Old January 19th, 2016, 10:15 AM
JackJack56Olds's Avatar
I'm trying to make sure I've got my lines correct. I have one vacuum line coming from under the dash through the firewall. It goes into a T with another line that comes from a port on the left of the wiper motor. Both of these lines ran to a hard line that connected to the fuel pump. Is this correct?
Also, does the line run through the 2 clamps on the firewall next to the heater box?
One more thing. There is a port on the top front of the wiper motor in the middle. I have nothing going to that. Is that correct?
Thanks!
https://classicoldsmobile.com/forums...1&d=1453227249
JackJack56Olds is offline
Old January 19th, 2016, 02:15 PM
Frank Ignachuck
ignachuck's Avatar
I had to think for a minute as I was reading your text, because I always want to go from the source in, and your description went from the switch out, but your plumbing looks correct.
The port on the front of the motor is a vent. Nothing gets connected to it.
Frank
ignachuck is online now
Old January 20th, 2016, 09:21 AM
Cool. You just can't find this stuff on google images like you would want. Any help on the lines that run from the washer jar to the firewall by the heater core hoses under the dash? Mine were all broken and missing. I don't know what goes where. Thanks!
Old January 20th, 2016, 03:48 PM
Frank Ignachuck
ignachuck's Avatar
Gordon (Olds Dad) nailed this back in 2011 with this excellent drawing.
Here's his diagram, hope you can open it.
Old January 20th, 2016, 05:42 PM
Fenian16's Avatar
I found this image for the vaccuum line routing on a 56 Buick while searching for the same info on my 55 Olds. Hope it helps.
Fenian16 is offline
Old January 21st, 2016, 10:03 AM
Dang, I can't open it! Is there somewhere else I can view this? I think its what I need.
Old January 21st, 2016, 10:39 AM
Frank Ignachuck
ignachuck's Avatar
https://classicoldsmobile.com/forums...-schematic.jpg
That should do it.
Old January 21st, 2016, 06:58 PM
Awesome thank you!
Old January 24th, 2016, 12:00 PM
The_German's Avatar
I believe that there is a vacuum buffer tank involved too?
The_German is offline
gmiles
August 28th, 2013 03:49 PM
victorMhernandez
July 7th, 2012 12:44 PM
alwayssomething
January 29th, 2010 06:52 PM
StarfireFox62
September 25th, 2008 01:29 PM
bbock
June 5th, 2006 11:50 AM
Quick Reply: Need help with vacuum lines on '56 Olds
