Need help with vacuum lines on '56 Olds
Old Jan 19, 2016 | 10:15 AM
JackJack56Olds's Avatar
I'm trying to make sure I've got my lines correct. I have one vacuum line coming from under the dash through the firewall. It goes into a T with another line that comes from a port on the left of the wiper motor. Both of these lines ran to a hard line that connected to the fuel pump. Is this correct?
Also, does the line run through the 2 clamps on the firewall next to the heater box?
One more thing. There is a port on the top front of the wiper motor in the middle. I have nothing going to that. Is that correct?
Thanks!
https://classicoldsmobile.com/forums...1&d=1453227249
Old Jan 19, 2016 | 02:15 PM
ignachuck's Avatar
Frank Ignachuck
I had to think for a minute as I was reading your text, because I always want to go from the source in, and your description went from the switch out, but your plumbing looks correct.
The port on the front of the motor is a vent. Nothing gets connected to it.
Frank
Old Jan 20, 2016 | 09:21 AM
Cool. You just can't find this stuff on google images like you would want. Any help on the lines that run from the washer jar to the firewall by the heater core hoses under the dash? Mine were all broken and missing. I don't know what goes where. Thanks!
Old Jan 20, 2016 | 03:48 PM
ignachuck's Avatar
Frank Ignachuck
Gordon (Olds Dad) nailed this back in 2011 with this excellent drawing.
Here's his diagram, hope you can open it.
Old Jan 20, 2016 | 05:42 PM
Fenian16's Avatar
I found this image for the vaccuum line routing on a 56 Buick while searching for the same info on my 55 Olds. Hope it helps.
Old Jan 21, 2016 | 10:03 AM
Dang, I can't open it! Is there somewhere else I can view this? I think its what I need.
Old Jan 21, 2016 | 10:39 AM
ignachuck's Avatar
Frank Ignachuck
https://classicoldsmobile.com/forums...-schematic.jpg
That should do it.
Old Jan 21, 2016 | 06:58 PM
Awesome thank you!
Old Jan 24, 2016 | 12:00 PM
The_German's Avatar
I believe that there is a vacuum buffer tank involved too?
gmiles
Aug 28, 2013 03:49 PM
victorMhernandez
Jul 7, 2012 12:44 PM
alwayssomething
Jan 29, 2010 06:52 PM
StarfireFox62
Sep 25, 2008 01:29 PM
bbock
Jun 5, 2006 11:50 AM
