manual to power steering on a 56 ?????
Trying to convert my manual steering into powersteering. I got me a saginaw box for a 56 but it looks like the column is also different. The powersteering one takes a rag joint and the manual one looks splined in. Anybody ever do this convertion before? Do I have to get rid of the column or is there an extra piece for the pw/s boxes?
Thanks in advance
Erit
Thanks in advance
Erit
I don't know if the power steering changed in 55 or 56. The 54 had a shaft that came out o power steering box and went all the way to the steering wheel where it had splines and was threaded to put the steering wheel on. Not a great safety feature.
The manual one is like that but the power assist one has a rag joint. Also for any one looking the gearbox is a one year (1956) only box. It fits out of Cadillac, Pontiac, and Oldsmobile. The column is only out of Oldsmobile but there is two kinds early, late model. A few things change; the column drop(two piece and three piece) The signal switch (one has wires that come all the way from the switch, the other has a rod that activates the switch at the bottom only wire in column is the horn), and the shifter lever (one screws in the other has a pin that holds it in place)
67Olds442X2
Suspension & Handling
December 21st, 2010 06:17 PM
77oldsprostreet
October 25th, 2009 04:58 PM
