manual to power steering on a 56 ?????
Old Oct 11, 2009 | 07:07 AM
hialeah56's Avatar
1956 holiday coupe
Trying to convert my manual steering into powersteering. I got me a saginaw box for a 56 but it looks like the column is also different. The powersteering one takes a rag joint and the manual one looks splined in. Anybody ever do this convertion before? Do I have to get rid of the column or is there an extra piece for the pw/s boxes?
Thanks in advance
Erit
Old Oct 11, 2009 | 03:00 PM
citcapp's Avatar
Don't have an answer for you, but I'll dig around and see what I can find out
Old Oct 11, 2009 | 04:02 PM
hialeah56's Avatar
1956 holiday coupe
thanks
Old Oct 14, 2010 | 08:12 PM
Frank Allen's Avatar
power steering 56 olds
you need the steering column with the rag joint, the power steering gear box , pump and brackets, and a double groove pully on crank shaft and water pump.
Frank allen
Old Oct 14, 2010 | 09:38 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I don't know if the power steering changed in 55 or 56. The 54 had a shaft that came out o power steering box and went all the way to the steering wheel where it had splines and was threaded to put the steering wheel on. Not a great safety feature.
Old Oct 17, 2010 | 05:51 PM
hialeah56's Avatar
1956 holiday coupe
Frank allen
thanks for the info, and yes you're right I already have the gearbox and the rag joint column btw I was thinking of going with a more modern 605 gearbox which I've been told fits right in. BTW this topic is a little old I asked this in 2009
The manual one is like that but the power assist one has a rag joint. Also for any one looking the gearbox is a one year (1956) only box. It fits out of Cadillac, Pontiac, and Oldsmobile. The column is only out of Oldsmobile but there is two kinds early, late model. A few things change; the column drop(two piece and three piece) The signal switch (one has wires that come all the way from the switch, the other has a rod that activates the switch at the bottom only wire in column is the horn), and the shifter lever (one screws in the other has a pin that holds it in place)
4speedBench
Nov 20, 2014 08:25 AM
russell-t
May 1, 2011 08:57 AM
67Olds442X2
Suspension & Handling
Dec 21, 2010 06:17 PM
77oldsprostreet
Oct 25, 2009 04:58 PM
hialeah56
Oct 11, 2009 07:01 AM
