Can I switch from power steering to manual in my 77 Cutlass
I have a 1977 Olds Cutlass with power steering and I want to covert to manual steering , can this be done .I know it involves getting a manual gearbox , but I heard the pitman arm needs to be changed out to, but can;t find a manual pitman arm for 77 Cutlass, any help would be greatly appreciated
I had to make a pitman arm, either do that, or live with the drag link being 1/2" out of level.
It's creepy either way. There is a guy in canada that did this conversion as well over on Realoldspower.com, but he never got back to me as to how he worked the problem out.
just find a 64- 72 a body,cutlass,chevelle,lemans,gto,skylark alot of the early ones had manual steering and that box should bolt up. you may also need the early rag joint as i think the shafts is a different size on the early boxes..
Power steering pitman arms and manual pitman arms have totally different splines.
