Can I switch from power steering to manual in my 77 Cutlass
Old Oct 24, 2009 | 04:32 PM
77oldsprostreet's Avatar
I have a 1977 Olds Cutlass with power steering and I want to covert to manual steering , can this be done .I know it involves getting a manual gearbox , but I heard the pitman arm needs to be changed out to, but can;t find a manual pitman arm for 77 Cutlass, any help would be greatly appreciated
Old Oct 24, 2009 | 06:30 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I had to make a pitman arm, either do that, or live with the drag link being 1/2" out of level.
It's creepy either way. There is a guy in canada that did this conversion as well over on Realoldspower.com, but he never got back to me as to how he worked the problem out.
Old Oct 24, 2009 | 06:33 PM
jaunty75's Avatar
Why did you have to make one? Was manual steering not available on '77 Cutlasses?
Old Oct 24, 2009 | 07:05 PM
I have never seen manual steering on any metric Oldsmobile.
Some Chev S-10's had it, but that's about it.
Old Oct 24, 2009 | 07:51 PM
leadfoot067's Avatar
just find a 64- 72 a body,cutlass,chevelle,lemans,gto,skylark alot of the early ones had manual steering and that box should bolt up. you may also need the early rag joint as i think the shafts is a different size on the early boxes..
Old Oct 24, 2009 | 09:42 PM
It will bolt up, but the pitman arm will be 1/2" out of level. The rag joints are different as you pointed out.
Power steering pitman arms and manual pitman arms have totally different splines.
Old Oct 25, 2009 | 04:58 PM
leep's Avatar
why?
4speedBench
Nov 20, 2014 08:25 AM
69442murph
Apr 9, 2014 09:42 PM
russell-t
May 1, 2011 08:57 AM
hialeah56
Oct 17, 2010 05:51 PM
hialeah56
Oct 11, 2009 07:01 AM
