Crankshaft Oil Slinger 64 394
Old Jul 21, 2024 | 02:54 PM
Cutman's Avatar
Restoring a 1964 Fiesta wagon. I am currently dead in the water trying to find the oil slinger behind the timing gear on the crankshaft. Does any one know where to get one or a cross reference of other Olds engines and years that will work? OPG showed to have one, but it has been on back order for about a month.
Cutman
Old Jul 21, 2024 | 03:47 PM
rocketraider's Avatar
Oldsdruid
Jan 65 parts book indicates 1949 thru 1958, then 1961 thru 1964 engines except the F85 215 and 64 330 all use the same crank oil slinger.
Grp 0.648 p/n 570696.
That gives you a pretty wide selection of engines to source it from. 303, 324, 371, 394 EXCEPT a 59-60 371 or 394.
Old Jul 22, 2024 | 05:48 PM
davek1661's Avatar
I just rebuilt a 1964 394 V8 for my Dynamic- pray tell, what is an "oil slinger"? Behind the timing gear? I'm trying to remember what was behind my timing gear, besides the block... Is it a flat circular piece of metal with a notch for the crankshaft keyway? It goes behind the timing the gear? Is that right? If so, I put mine between the timing gear and the front cover oil seal. I'm thinking it still slings the oil... details, details!
Old Jul 24, 2024 | 09:57 AM
Cutman's Avatar
Thanks for the info! The Oil slinger from what i have read keeps the oil from hitting the seal on the timing cover and creating a leak over time. It is the part as you have described right behind the timing gear on the crank. As fate would have it, Mondello called me the day after I posted my question. It took them 3 weeks to reply as there was an illness in the company. They have one for $30 + Freight and it's on it's way. As I'm sure you know, getting parts for a 64 394 and a Dynamic 88 can be challenging. If you have any sources besides Fusick please share. Where did you get the parts book from 65?
Old Jul 24, 2024 | 01:07 PM
Oldsdruid
I found that parts book at a swap meet, probably a Carlisle meet, 30+ years ago.
Here's the 49-64 Rocket engine oil slinger detail diagram from that parts book.
Old Jul 25, 2024 | 02:34 PM
Cutman's Avatar
NIce picture. Doing a complete front suspension today. Do you have any parts sources?
Old Jul 25, 2024 | 02:39 PM
Cutman's Avatar
relooked at the diagram and it is showing the slinger on the outside of the timing Gear. Mine was on the inside and bet that's why it's bent. I guess the timing cover holds it in place? Do you know what keeps it on the crank?
eggydrummer
Oct 1, 2024 04:48 PM
twiggy
Nov 24, 2022 09:27 PM
Husky701
Jan 30, 2021 06:02 AM
jcdynamic88
Feb 21, 2015 03:33 PM
Swed Olds
Jul 15, 2010 12:21 AM
