brake fluid
Old Apr 10, 2020 | 08:31 AM
yesiwood's Avatar
brake fluid
what type fluid for 57 rocket 88 power brakes
Old Apr 10, 2020 | 09:12 AM
Charlie Jones's Avatar
Phantom Phixer
Dot 3
Nomadoc's Avatar
Type 3 or 4 will work. They can be interchanged.
Just don’t mix Type 5 (silicone based) with 3 or 4.
If the car is new to you and you don’t know what is in the reservoir then suck a little out and see if it blends with what you want to put in. Type 5 will turn milky if you mix it with 3 or 4.
I had a Buick that had type 5 in it and didn’t know......had to replace every component of the hydraulics!!
Bill
Old Apr 10, 2020 | 01:34 PM
Sugar Bear's Avatar
Motorcraft DOT 3 has good specs...if my research is correct, it exceeds some DOT 4 formulas. IIRC the trade off is 4 absorbs moisture quicker which could matter on an infrequently driven car.
Now for the big question...would that be "Keeping your GM car all GM" ???
Old Apr 11, 2020 | 08:33 PM
Ozzie's Avatar
The 1957 Oldsmobile Shop Manual specifies GM brake fluid No. 11.
Old Apr 15, 2020 | 06:57 AM
yesiwood's Avatar
Thanks sir
72w442
Brakes/Hydraulic Systems
Dec 14, 2014 10:16 AM
805cut
Sep 25, 2012 01:59 PM
Joffroi
59
Feb 24, 2011 07:22 AM
cfair
Jun 8, 2009 12:37 AM
southcarolina803
Sep 28, 2008 03:06 PM
