brake fluid
Type 3 or 4 will work. They can be interchanged.
Just don’t mix Type 5 (silicone based) with 3 or 4.
If the car is new to you and you don’t know what is in the reservoir then suck a little out and see if it blends with what you want to put in. Type 5 will turn milky if you mix it with 3 or 4.
I had a Buick that had type 5 in it and didn’t know......had to replace every component of the hydraulics!!
Bill
Bill
Motorcraft DOT 3 has good specs...if my research is correct, it exceeds some DOT 4 formulas. IIRC the trade off is 4 absorbs moisture quicker which could matter on an infrequently driven car.
Now for the big question...would that be "Keeping your GM car all GM" ???
72w442
Brakes/Hydraulic Systems
Dec 14, 2014 10:16 AM
cfair
Jun 8, 2009 12:37 AM
