Bolt for brake arm
Bolt for brake arm
Hello All,
I'm looking for the brake arm bolt that holds the arm to the chassis. It slides through the arm hole that has a zert fitting to lube it. My car is a 1953 Oldsmobile Super 88 4 door. I cant seem to find it anyplace. Are there any other options for it? Thanks for the help.
Jesse
Jesse
I don't have one for sale but i can give you the dimensions of the one i have, the brakes are currently apart anyway, maybe find something comparable on McMaster-Carr or Fastenal. I'll measure it when i get home form work tonight.
Not really a bolt
more of a shaft with a tapped hole, i cant remember exactly how it was attached to the frame, I grabbed the manual brake set up off my parts car to get rid of the bendix treadle vac set up.
