Bolt for brake arm
Old Jul 1, 2022 | 08:29 AM
Navyman53's Avatar
Bolt for brake arm
Hello All,
I'm looking for the brake arm bolt that holds the arm to the chassis. It slides through the arm hole that has a zert fitting to lube it. My car is a 1953 Oldsmobile Super 88 4 door. I cant seem to find it anyplace. Are there any other options for it? Thanks for the help.
Jesse
Old Jul 1, 2022 | 09:51 AM
ub2693v's Avatar
I don't have one for sale but i can give you the dimensions of the one i have, the brakes are currently apart anyway, maybe find something comparable on McMaster-Carr or Fastenal. I'll measure it when i get home form work tonight.
Old Jul 2, 2022 | 02:01 PM
ub2693v's Avatar
Not really a bolt
more of a shaft with a tapped hole, i cant remember exactly how it was attached to the frame, I grabbed the manual brake set up off my parts car to get rid of the bendix treadle vac set up.
Old Jul 2, 2022 | 04:09 PM
Navyman53's Avatar
Is that a 3/8-16 bolt and THANK you. Your a lifesaver.
Old Jul 2, 2022 | 05:28 PM
ub2693v's Avatar
Looks to be a 5/16 bolt, not sure if it’s 18 or 24 threads per inch, the bolt is 3/4” without measuring the head, I counted approx 17 threads so probably safe to say it’s 24tpi.
good luck!!
Navyman53
Brakes/Hydraulic Systems
Jun 29, 2022 07:57 AM
Kreisk
Jun 5, 2022 07:20 PM
vt324
Sep 6, 2021 03:09 AM
72455
Oct 16, 2019 06:59 AM
