battery for L-37
Old Jan 11, 2019 | 02:58 PM
dbandgb's Avatar
battery for L-37
Like I said in my newbe section I have a L-37 4dr. touring. I have all the manuals I can buy. I am just getting started to work on it. Motor turns free. I need to buy a battery and in the manual it says a Delco 17-T. It does not say anything about cranking amps. . It is the long 6 volt. Any idea of cranking amps.? 8 cyl. Thanks Gary
Old Jan 11, 2019 | 05:00 PM
1970cs's Avatar
Lansing built
See if this helps? https://www.oreillyauto.com/detail/b...ery/2e/4742620
Old Jan 11, 2019 | 06:55 PM
Tedd Thompson's Avatar
Other than the quality of the battery which I don't remember what I used back then the size of the battery cables are the next most important thing. Don't use cables that are designed for 12 volt cars or you will fight cold day starts. or hot day starter issues. I believe I used 00 cables found at the tractor supply store for my best results..... Tedd
Old Jan 12, 2019 | 08:20 AM
dbandgb's Avatar
Thanks for the reply. I already bought the 00 cables.
Old Jan 12, 2019 | 09:22 AM
dbandgb's Avatar
Originally Posted by 1970cs
Now this looks like it will do the trick. Thanks for the reply. We have an Oreilly down here.
Old Jan 12, 2019 | 04:05 PM
Charlie Jones's Avatar
Phantom Phixer
These " long Tom " batteries were only used from 1937 thru 54 on some , but not all , Buick , Pontiac , and Oldsmobiles .
Their saving grace , as far as availability , is that they were also used on John Deere tractors in about the same time period .
Old Jan 12, 2019 | 04:55 PM
dbandgb's Avatar
Mine came with the long batter holder bolted to the top of the frame in front of the firewall on drivers side.. It had a battery in the holder but have no idea of quality. It has not run since 1974 so I have a lot of checking before trying to start it. Pull the pan etc.
FStanley
Feb 28, 2023 02:48 PM
auto_editor
Mar 26, 2015 09:20 AM
VikingBlue
Feb 11, 2012 10:24 AM
68Tom
Mar 20, 2009 08:50 AM
Pfiffle
Mar 3, 2008 08:01 AM
