Autronic Eye Bypassed
Old December 29th, 2017, 01:23 PM
ponder48's Avatar
The autronic eye on my 55 Olds does not work. Someone had rigged the lights to work without it when I bought the car several years ago. Now when the headlight switch is pulled all the way out all headlights and taillights go out and I can hear a slight noise that sounds a little like an electrical arc, but cannot see any such. There is also a noise like a relay kicking in and out. I would like to completely by pass all the eye circuitry and go directly from the headlight and dimmer switches to the headlights and use the lights as if there had never been an eye. However, I have not been able to locate a wiring diagram complete enough to show me which wires to delete and which to tie together to do what I want to do. Any help out there?
ponder48 is offline
Old December 29th, 2017, 02:00 PM
I moved your post to its own thread. Someone else maybe can provide the stock headlight wiring diagram.
oldcutlass is online now
Old December 29th, 2017, 02:44 PM
Proud Viet Nam Veteran
redoldsman's Avatar
If you have a factory shop manual it should show the wiring diagram.
redoldsman is offline
Old December 29th, 2017, 03:23 PM
Frank Ignachuck
ignachuck's Avatar
Here is the 1956 Schematic which may or may not help
ignachuck is offline
Old December 29th, 2017, 03:33 PM
ponder48's Avatar
Thanks. That looks pretty much like the 55 schematic. Will see what I can do with this.
ponder48 is offline
Old December 29th, 2017, 05:16 PM
m371961's Avatar
The noise you hear may be the circuit breaker made in the switch.
m371961 is offline
Old January 9th, 2018, 05:41 AM
zzcruzin's Avatar
On my 54 Chevy Bel Air, I took the lid off the black box and at the very bottom, there is a fuse. I removed it and the lights worked like normal. High beam and low beam. Before you remove it, you could also turn the lights on and see if the vibrator is humming inside the black box with the lid off.
zzcruzin is offline
belgium57olds
March 3rd, 2013 04:57 AM
deaddds
Ninety-Eight
February 2nd, 2013 08:43 AM
67 Cutlass Freak
May 5th, 2012 09:31 AM
hialeah56
October 25th, 2009 06:02 PM
Quick Reply: Autronic Eye Bypassed
