Another OEM Visor Wrapper-1954 Olds Super 88 Power Brakes
Old Jul 1, 2025 | 09:42 AM
justacog's Avatar
Hi All. I posted sometime back the driver side visor wrapper, that described the operation of the Hydramatic transmission, that the 1954 Oldsmobile Super 88 came with new from the factory. I found this additional visor wrapper describing the operation of the power brake system. The 1954 had a vacuum reserve tank on the underside of the chassis on the driver side that stored vacuum for emergency brake use. It was controlled by a solenoid which opened up when the brake pedal was depressed (hooked to the taillight switch).
Maybe this will help someone at a car show for "original" restoration points (if that's a thing). The pdf is scaled to the proper size. The original wrapper text is upside down on the backside on purpose so that the text is "upright" when the visor is flipped down.
Anyway...Enjoy and I hope this is of use to someone!
justacog
Nov 30, 2023 09:34 AM
72cuttys
Apr 21, 2022 05:02 PM
crazzmc
Brakes/Hydraulic Systems
Apr 19, 2020 12:56 AM
Dad-Par
Mar 30, 2020 12:21 PM
bauerterry
Feb 22, 2020 11:24 AM
