Power brake question
Old Feb 10, 2020 | 03:50 PM
bauerterry's Avatar
I just had power brake booster on 56 super 88 rebuilt and have a few questions. How much brake pedal throw is normal, I had the booster rebuilt because there was almost no throw when brakes applied, the car stopped fine but just thought I would rebuild it, now after install and bleed it does not seem much better. I replaced the vacuum hoses and checked vacuum and check valve, it holds vacuum at a minimum of 20 in Hg of vacuum. Any help and comments appreciated.
Old Feb 22, 2020 | 10:16 AM
twintracks's Avatar
Did you do the brake shoe adjustment procedure?
Old Feb 22, 2020 | 11:24 AM
So the only issue was you didn't think the "throw" seemed right?
And what exactly do you mean by that? Did you think the pedal did not depress far enough or did it depress too far?
63super88
Mar 18, 2014 02:03 PM
Raydermiike
Brakes/Hydraulic Systems
Sep 4, 2013 03:00 PM
rcrac3r
Jul 19, 2013 12:38 PM
iuhoops83
Oct 7, 2009 09:30 AM
54olds
Jun 25, 2008 12:46 AM
