ad on oiling OLD SCHOOL HOT ROD
Old Sep 12, 2010 | 03:43 AM
Cari43's Avatar
Need a top end ad on oil kit for 324 v8 1955 1417 624 3734 mike need more oil to rockers
Old Sep 12, 2010 | 07:05 AM
Bluevista's Avatar
Registered
I had a '55 furd in '73 and the 292's and 312s had same upper oiling problems.
I was told the kits were common at parts stores back in the day, a coil of copper tubing and brass compression fittings, you would tap in at the oil filter gauge sending unit fitting then run lines to the top of the valve covers. You just just let the oil squirt through holes with fittings in two spots on each cover on to the rocker arms.
You can buy all the stuff at the hardware store if you know what it's supposed to look like, that's what I did.
Old Sep 12, 2010 | 08:25 AM
redoldsman's Avatar
Proud Viet Nam Veteran
You really need to fix the problem and not slap a bandaid on it. The oiling system worked when new and can be made to work again. Just takes a little work and money.
Blu, those were very common on Y-block fords with some miles on them.
brandon 455
Nov 7, 2013 06:47 PM
Jen
Dec 3, 2012 03:27 PM
Rowdies
Feb 10, 2012 07:57 PM
1969goatman
Sep 21, 2009 07:59 PM
<ohio2atl>
Jan 28, 2005 11:38 AM
