'55 2 Door Post 3-speed Restoration
Old Aug 22, 2012 | 09:38 AM
  #41
WHIPOLDS's Avatar
Olds Dad - I have been looking into getting my wonderbar radio converted to AM/FM . The places I spoke with advised they could make the signal seeking wonderbar function. It adds about $150.00 to the cost. I am trying to decide wether to use the push button radio from my parts car and save the wonderbar. The price I got for conversion for the push button was $395.00. To do the wonder bar I was told about $500.00.
Still trying to decide which way to go.
Rick
Old Aug 22, 2012 | 09:42 AM
  #42
D. Yaros's Avatar
Keep the wonderbar, and add a fm tuner (housed in the glove box) and used by tuning to a specific frequency on the am dial), would be the course I would choose.
Old Sep 4, 2012 | 08:30 PM
  #43
Olds Dad's Avatar
Collector of Stray 55's
UPDATE:
So, between brake woes on my driver, and general life, I've been able to do only some small stuff.
I managed to get the nose off - so now, all the bolt on stuff is off.
Removed the clutch & brake pedals, steering mast, and everything on the firewall.
I need to remove the steering box and then I'm going to pull the engine and start detailing the front clip.
I did manage to clean up and detail my front bumper brackets and hardware - so I still feel like I'm gradually moving forward...
Stay with me, this car will get done!
Old Sep 21, 2012 | 08:07 PM
  #44
Olds Dad's Avatar
Since I wasn't getting anywhere with the brake issue on my driver tonight, I focused on reassembling the heater box / blower motor assy
Here is a before picture, and the after shots.
Used the correct cloth wire for the lead and grounds, as well as the original connectors (after melting away the original solder) -
The beast in the background is Gromitt...one of my two Great Danes and a constant garage companion.
Old Sep 28, 2012 | 09:23 PM
  #45
Olds Dad's Avatar
Got the dash bezels back from the plater...boy are these pretty
Old Sep 29, 2012 | 03:51 AM
  #46
golds56's Avatar
nice sparklers,does she want to wear them on her ears?Who is doing your plating ,my plater did a nise job but ruined the trunk handle and there arent many to be found so when i find one i want to have someone else do it.
Old Sep 29, 2012 | 09:16 PM
  #47
Olds Dad's Avatar
I have a local guy here in Providence (D&D) - he's pretty good with small stuff, but not much in the way of problem pieces...most of what he's done for me was pretty good to start with - I think for something tough, you need to pay the money and go to Paul's Chrome (only place Mike Fusick uses...including for his '53 Fiesta he's restoring). I'd guess your trunk emblem would cost you about 4-5 Franklins, but it would be perfect
Old Aug 23, 2013 | 05:54 AM
  #48
Olds Dad's Avatar
Finally an update
So, I haven't updated this thread in a while largely because I've been at a standstill with this car...between the under floor brakes on my driver, work, kids, and home improvements, spare minutes have been few and far between.
However, I'm back to it.
Here are a few pics of the front door vent window assemblies. Bought the rubber gaskets and the "fuzzy" channels through Fusick (although the rubber is from Steele).
New glass, rechromed frames, new channels, new slide locks (got from a Chebby catalog) and a few "Pop" rivets.
I rebuilt an extra set I had, so there's an old set in the "before and after" photos for comparison.
Old Aug 23, 2013 | 07:35 AM
  #49
Tedd Thompson's Avatar
Gordon good to see the resto going again. I had to reread all the posts to get my head around where you were at. I know it seams like it's a slow processes but when I look back It took me 4 years on mine also and I had help at times, press on my man....Tedd
Old Aug 23, 2013 | 07:56 AM
  #50
Olds Dad's Avatar
Thanks Tedd - behind the scenes has been a lot of research, parts acquisition, and general organization. I'm lucky to have a good sized shop so at least when I'm not working on them, they're sitting inside and not deteriorating outside under a tarp.
I will get there - I always finish what I start - even if it takes years - my 71 convertible took me about 4 years...and I was single then!
Old Oct 17, 2013 | 10:14 AM
  #51
Olds Dad's Avatar
Update
Managed to find everything I needed for the 57 371 that I needed...heads, exhaust manifolds, distributor, and a gorgeous J-2 setup.
I'd love to have the original 324, but it's long gone, so the '57 371 with the J2 it will be.
I cleaned a up a few things...not the least of which is the throttle linkage that will run this setup.
If anyone knows what piece is missing from the hole in the airhorn of that center carb, let me know.
Old Oct 17, 2013 | 03:00 PM
  #52
citcapp's Avatar
I checked my pictures from when I had a J2 in my 57. Did not have a hole on the center carb. Checked a number of other pictures on J2 set ups and did not see anything there either. Mystery?
Old Oct 17, 2013 | 06:56 PM
  #53
Gordon
Isn't the center carb on a j2 a 2gc and if so someone should have a schematic of one, in fact I might somewhere in my junk I'll take a look tomorrow.....Tedd
PS. good to see you are back at it.
Old Oct 18, 2013 | 05:33 AM
  #54
Olds Dad's Avatar
I plan to look a lot closer at it all this weekend - I did similar "photo" research and also found no others similar.
Thanks for your efforts - I'll let you know what I find out
Old Oct 18, 2013 | 05:37 AM
  #55
Olds Dad's Avatar
Gordon
Isn't the center carb on a j2 a 2cg and if so someone should have a schematic of one, in fact I might somewhere in my junk I'll take a look tomorrow.....Tedd
This is my first foray into J-2s. I've never tinkered with them - I'll try to get my feet wet this weekend on it and see. If you have one kicking around it'd be great.
I emailed a couple of carb shops with the photo and carbs.net directed me to a 'vent' multi pack that he sells. I'm sure it's not a big deal, but just not being familiar with them puts me at a disadvantage
I appreciate your efforts
Old Oct 18, 2013 | 12:27 PM
  #56
D. Yaros's Avatar
I, for one, would like to see some pics of the manual tranny when you get to that part of the resto.
Old Oct 18, 2013 | 12:34 PM
  #57
Olds Dad's Avatar
Will do!
Old Oct 18, 2013 | 07:02 PM
  #58
Gordon, Take a look at your 55 manual it has a breakdown of the 2GC on page 294 through page 307. I believe this is the same carburetor or very closic to it and the part in question is called a atmospheric vent rubber valve. Looks like if it ain't broke you don't need to fix it.
You might want to compare the two carbs closely to double check on their similarities also I have heard that the outside carbs are 2G's almost the same carb but without the choke setup.....Tedd
Old Oct 21, 2013 | 06:44 AM
  #59
Olds Dad's Avatar
thanks Tedd -
The vent valve is just plain missing is the problem - I did find a similar schematic to what you mention.
I found a Rochester Manual online for the J2 setup (Service Notice)
Looks like the outer carbs are 2G's without the idle circuits (and chokes as you mentioned).
Old Feb 28, 2014 | 10:39 AM
  #60
Olds Dad's Avatar
Well, the arctic tundra that is New England gave me a rare above-freezing day last weekend
I've been itching to do something on this car - so I rolled it out of the garage and pulled the driveline.
The heads are being rebuilt and I plan to start detailing the front end now that the engine is out - and opening up that syncromesh to see what's up in there.
At least I'm moving!
Old Feb 28, 2014 | 12:14 PM
  #61
pcard's Avatar
70 Cutlass SX
Gordon - I do not know how you were working outside last weekend! I was in Newport for 10 days and froze everything off. My wife is still up there and says it is too cold to go anywhere.
I would love to get together with you next time I am in the US. My wife has lots of family in Pawtucket and we visit often when in RI.
Old Feb 28, 2014 | 12:35 PM
  #62
Olds Dad's Avatar
Ha! Last Sunday was in the low 50s - after months of freezing, it felt like Bermuda!
I'm one town over from Pawtucket - PM me next time you're in town!
Del70
Jul 21, 2020 11:42 AM
tylertravismya
Oct 11, 2014 04:30 AM
tylertravismya
Oct 4, 2014 06:35 PM
fknrc
Nov 7, 2012 08:01 PM
