54 Olds Brake Backing Plate Gaskets
Old Dec 14, 2023 | 11:22 AM
justacog's Avatar
Does anyone know of a source for the front axle brake backing plate gaskets for a 1954 Oldsmobile Super 88? There is a gasket on either side of the backing plate on the front brakes, a simple round one on the outside of the backing plate and a larger one on the inside. Attached is a picture of what I'm looking for. I talked to Fusick and they weren't aware of any gaskets on the front backing plates (I did see that they list gaskets for the rear axle backing plates). I can always make my own from some paper stock but I'd rather just buy premade ones if available). I was only able to salvage a small piece of the out gasket (that semi-circle sitting in the middle of the larger inner gasket.
1954 Olds Super 88 front brake backing plate gaskets
Old Dec 14, 2023 | 12:28 PM
justacog's Avatar
I did notice just now this thread from last year:
https://classicoldsmobile.com/forums...gasket-164786/
with the same questions. I can confirm that there absolutely are two gaskets on the front backing plate of a 1954 Super 88 (and probably the same for a 1955) as the remnants above show. They are just super thin paper ones and easy to destroy when pulling off the plates.
Old Dec 14, 2023 | 12:32 PM
BobsFiftyEight's Avatar
Tool Freek
1955 Oldsmobile Master Chassis Parts book shows group #6.038 gasket, front brake oil drain part #411196 (fits 1939 thru 1955 maybe more)
Another member on this forum said he purchased the gaskets from Fusick I believe
Bob
VI Cutty
Brakes/Hydraulic Systems
Sep 2, 2023 01:47 PM
nickwisconsin
Oct 1, 2022 09:05 PM
ub2693v
Jun 3, 2022 11:56 AM
oldzy
Drivetrain/Differentials
Sep 27, 2010 05:49 AM
stuart
Dec 16, 2004 09:23 PM
