55 olds front axle backing plate gasket
Old Jun 2, 2022 | 10:20 AM
ub2693v's Avatar
Hello everyone, i am getting ready to re-assemble my front suspension/brakes and i can't find the paper gasket that goes between the hub and the backing plate, fusick shows the rear but i can't find the front. Anyone know if this part is available?
Old Jun 2, 2022 | 07:56 PM
Charlie Jones's Avatar
Phantom Phixer
You won't find a gasket, because there never was one there.
The backing plate bolts directly on the spindle. No gasket or sealer required.
Old Jun 3, 2022 | 02:59 AM
ub2693v's Avatar
I definitely removed a very thin paper gasket, I remember trying to save it but it ripped into several pieces.
Old Jun 3, 2022 | 07:27 AM
Tedd Thompson's Avatar
I don't remember one also, but if you feel better with one use gasket material and make one. Tedd
Old Jun 3, 2022 | 07:39 AM
Phantom Phixer
Opon further review...........
I checked in an older parts book and found the following ; Group 6.038 Seal, front wheel backing plate. Part # 562419.
I googled the number and came up with nothing.
Since it was a thin paper gasket, I would suggest smearing the surfaces lightly with RTV silicone.
Put it together, and call it a day.
Old Jun 3, 2022 | 08:29 AM
ub2693v's Avatar
This is what shows up from Fusick, the circled is kind of what i remember the shape being, (been over a year since i took it apart), so i guess i wrongly assumed that this set was for the rear axle only, so the round would be for the rear axle and the other must be the front?
Old Jun 3, 2022 | 11:56 AM
BobsFiftyEight's Avatar
Tool Freek
I believe Group # 6.038 Gasket, front brake oil drain starts at 1939 thru 1955 and possibly a lot longer as my book is effective January 01, 1955 and lists part number 411196.
Just above that to group # 6.037 which is just above the seal earlier, Deflector or Drain, front brake oil (shield or deflector on spindle)
I hope this helps.
Bob
rick442
Drivetrain/Differentials
Mar 7, 2019 04:03 PM
Olds Scott
Brakes/Hydraulic Systems
Apr 23, 2015 11:46 AM
oldzy
Sep 27, 2010 05:49 AM
mcutlass1969
Sep 22, 2010 12:48 PM
stuart
Dec 16, 2004 09:23 PM
