48 Olds steering box outer tube removal
Old Jan 30, 2021 | 02:35 PM
kjmmm's Avatar
How do I remove the outer tubing from the steering box? I have the steering wheel and all of the parts off the top. Is the tube pressed in or does the box have to come apart to unbolt this tube? Thanks to all for any help!!
Old Jan 30, 2021 | 06:37 PM
Charlie Jones's Avatar
Phantom Phixer
That "tube" is part of the steering box . It can't be removed .
Here is an illustration to show you how it all goes together ;
Old Jan 31, 2021 | 07:49 AM
kjmmm's Avatar
steering tube
This tube must be either welded or pressed into the steering box. I need to get it off in order to modify the shaft to u-joints for header clearance. I guess I will just cut it off and go from there. Thank you for the replies!!
Old Jan 31, 2021 | 08:01 AM
Phantom Phixer
That idea isn't going to work either . This box was built to work as one unit .
A better idea would be to get a steering box from a sixties or seventies GM car . Then build your own column with all the u-joints you need .
JOHNNYOLDS442
Jul 27, 2020 06:08 PM
Robert Kiedrowski
Jun 10, 2013 04:40 PM
at3reg98
Jun 4, 2012 12:03 PM
MJAKS462
Aug 17, 2010 03:19 AM
agtw31
Suspension & Handling
15
Jun 14, 2010 06:01 AM
