303 v8 dwell
Old Sep 11, 2024 | 01:01 PM
maineolds's Avatar
303 v8 dwell
Anyone know the factory correct dwell angle for a 1949 olds 88 with the 303 v8?
I see in my service manual that ideal points gap is .015
Thoughts welcome,
Nathan
Old Sep 11, 2024 | 01:09 PM
Sugar Bear's Avatar
I don't have a factory spec but believe that .015" point gap on an 8 cylinder should be very close if not exactly 30°. Recheck the dwell after a few miles as the rubbing block on the point set wears rapidly at first.
Old Sep 11, 2024 | 01:28 PM
.016 is the point gap to be close to a 30* dwell, timing should be between the 2 steel ***** on the crank pulley.
Old Sep 11, 2024 | 01:55 PM
maineolds's Avatar
Thanks friends. I just got my distributor back from Advanced Distributors. Jeff did a great job and found that I my distributor was inconsistently cutting out. It was rebuilt just a couple years back by another shop but evidently not very well. When I got it back I stabbed it in as it was sent back to me with new points and condenser. My dwell was showing 45 degrees so I figured I should adjust.
Old Sep 11, 2024 | 05:58 PM
Charlie Jones's Avatar
Phantom Phixer
My Motor's manual says that 1949 Olds with V-8 had a .016 point gap .
And 21-30 cam angle degrees.
The median of the 21 - 30 range is about 25 degrees.
You can adjust the points while cranking the engine.
Leave the points a little loose and nudge them one way or another while you watch the dwell meter.
Mike 1956 Olds 88
Jul 14, 2023 03:02 PM
Dave’s Holiday 55
Sep 18, 2021 07:48 AM
VE6STA
Sep 8, 2021 04:39 AM
Spartan707
Jan 22, 2021 11:31 AM
safetymike77
Jun 1, 2012 03:43 PM
