1957 Olds - routing a water temp sensor through the firewall
Old Sep 25, 2025 | 06:53 AM
WikedOldsmoileSupe88's Avatar
Good morning,
I'm installing a water temp gauge in my car. The problem is trying to find a spot to run the sensor out through the firewall. The water sensor end is rather large and I'm not seeing any specific place that I can pass the sensor through into the engine compartment. Does anyone know of any good locations? I know I can always drill a hole and use a grommet but thought I would ask first.
Thanks.
Old Sep 25, 2025 | 07:26 AM
jaunty75's Avatar
I'm curious. Whenever I've installed a temperature sensor, the sensor is separate from the wire that runs to it. I install the sensor and then just run the single wire through the firewall and screw it onto the sensor with a loop fitting crimped onto the end of the wire.
In your case, can the sensor be separated from the wire that attaches to it?
Old Sep 25, 2025 | 08:52 AM
redoldsman's Avatar
Proud Viet Nam Veteran
The non=electric temp gauges have the sensor built onto the line connected to the gauge. It can be very difficult to get through the firewall. I have usually been able to find a grommet to get it through.
Old Sep 25, 2025 | 10:57 AM
Yeah, as redoldsman said, mine is the non-electric kind so it makes it much more difficult. I may have to drill a hole and use a grommet if I can't find anything.
Old Sep 25, 2025 | 11:51 AM
Check above the brake and gas pedals for an OE hole in the firewall.
Old Oct 1, 2025 | 06:19 AM
I was able to get the sensor routed. I found a rubber grommet on the passenger side of the firewall. The rubber was dry and brittle so I removed it and some wires that did not appear to connect to anything. Once it was through and hooked up I replaced the old grommet with a new one to protect the sensor. I was amazed that the water temp sensor reached all that way. Thanks to everyone for the help.
olds 307 and 403
Sep 5, 2022 02:09 PM
pnagy23
Feb 25, 2022 08:46 PM
Drsantos
Aug 16, 2018 06:55 AM
olds88royalvert
Jun 11, 2011 04:29 PM
KQQLCAT
Nov 8, 2007 04:48 PM
