Yes, it was a remote oil filter that was mounted on the passenger inner fender. One line was hooked to stock oil filter housing and the other to a small port on front of block by water pump. Both lines were plugged with sludge.
Been driving car a while, she overheated yesterday, cleaned out radiator and flushed system. Had to solder a small leak around the cap mount. When out to check out car and smelled gas. The flexible fuel line that attaches to fuel pump was rotted out, replaced with a short section of fuel line. Engine is running better but getting some rocker noise. Will do another oil change after I replace valve cover gaskets.
