Working on manual brakes, cleaned gas tank, topped off rear end, changed engine oil and radiator fluid. Car has been off the road for a good long time. Should the transmission fluid be changed if it looks okay? Believe this is a jetaway (has park position).
Finally got the brake lines, wheel cylinders and rebuilt master cylinder installed. The one front passenger brake line was not fun. Bench bled master cylinder and will bleed system today. With any luck might take her for a spin.
I have a question that's been nagging me for years, but I never thought about asking about it until just now.
How do you access your master cylinder? Here's why I ask: My '56 has factory AC. To get at the master cylinder, I have to take off the left front wheel and remove an access panel on the rear of the wheel well and reach in to get the dipstick out. I can't even see the master cylinder from the engine compartment because the AC blower and evaporator unit are in the way.
I've often wondered if all '56's were like that, or if this access panel is unique to factory AC cars.
Inquiring minds want to know!!
My 88 is non power brakes, access is from underneath, no dipstick. Just a screw on cap right on the master cylinder, just enough room to fill it.
Did get the leaks fixed in all the new connections, two lines split off the front of master with one line to a front splitter near driver side wheel and one to rear splitter at rear axle. Got brakes bled but got dark outside, didn't want to take first spin at night.
Took rocket for her first ride, brakes work good, speedo, lights and turn signals work. Next up a tune up, put ethanol free gas in her, doesn't like it.
Had some time, so decided to install spin on oil filter adapter, no filter in canister on engine but a lot of sludge. Engine has an add on oil filter that is mounted under the hood on passenger wheel well. Have the adapter installed and used permatex on gasket. Now need to remove upper filter housing and the upper line that connects by the water pump. Concerned about the amount of sludge in lower canister, when I changed the oil the first time, oil was dirty but did not notice any sludge come out. Is it okay to use a detergent oil in this engine, used 10w-30 the first time. Engine runs good and quiet after fixing minor vacuum leak.
I use detergent type oil in my 55 with no problems for years but you may have a issue with sludge build up in the upper end that will stay gummed up even if you change your oil regularly. It may not hurt to pull a valve cover and see what it looks like before you run a bunch of miles on it...... Tedd
Thanks Tedd for your reply. Removed remote oil filter today, the return hose was pretty much plugged up. Pulled oil pan drain plug, drained the oil after warming it up. Warmed up the pan and fished a wire up into pan and pulled out more sludge. Draining the pan overnight. If any one wants the remote oil filter setup let me know, will need new lines.
If you plan on a short low RPM run it may suffice to add a quart of ATF to your next oil change and only run it a few miles before changing. You will be surprised at what will drain out of gunked up engine.
I always wonder why the previous owners go to all the trouble and expense to add something that isn't as good as what came from the factory..... Tedd
Your right about add on filter, car was found in a garage in 2014 and had not been touched since 1975. Have paperwork on the car back to the first oil change. Car was purchased in Flint MI. on may 24 1956 and driven to your state of California. Paperwork shows first oil change in CA. on 7-5-56 at Tom Ballard Olds in Reseda. Never had a car with such extensive paperwork. Will pull the valve covers and take a peek. Maybe after cleaning out top of heads I will try running some ATF. Love the picture of your "daughter" sitting in the convertible.
Original invoice for car shows $9.60 for oil filter. Had to take another shot at oil filter adapter, dripped oil. Made a gasket out of cork and used form a gasket liberally this time.
Ah, the lady is young enough to be my grand daughter but no relation. She was a model who came with a photographer when my car was used for a photo shoot...... Tedd
Gave up on the spin on oil filter adapter, after several attempts, even made a cork gasket, it drips. Instructions state to use RTV with the gasket but to leave attaching bolt an 1/8th of a turn loose for 24 hrs and then snug. Tried assembling with everything snugged up, drips. Sent email to guy selling this adapter on feebay and no response. Got a WIX canister filter and assembled with no leaks first try.
Chris, the oil filter was not standard on that engine to begin with. It was a $10. option. Mine came with that option and I got fancy a couple of years ago and installed a spin on adapter like you did. I couldn't get it stop leaking either. After several attempts, I went back to the canister. Hasn't leaked since.
Did a tune up on motor, dwell was way off, amazed it ran, two plugs were black, traced to distributor cap and set the timing. Minor carb adjustment and was running great, then started backfiring, ran it out of gas. Filled it was some ethanol free gas and she starts easily, runs good. Next project is to replace leaking radiator and lower hose out of the 98 parts car. Have the original statement of motor vehicle sale from May 24 1956. Jetaway trans 190, heater 77, deluxe radio 96, windshield washers 10.50, deluxe steering wheel 13.25, oil filter 9.60, exhaust extension 1.75 and special tutone paint 25. Under the equipment and accessories it list undercoat 25 and gas and polish 15.50. Under remarks it list discount of 627.34 .
Have put a few miles on car, changed radiator and flushed with water three times. Very dirty water, put some flush in system and will run for a little while. Next on to the transmission, it shift good but am heading suggestions and having fluid/filter change. The question is what type of fluid to use? Is Dextron III a good choice?
I had one of those oil filter adapters somebody had put on my 54. They had put epoxy or JB Weld around it to try and stop it from leaking. It didn't leak, it poured. I put an adapter from a later 394 that was made for a spin filter. While I was at it I installed a pressure switch for my electric fuel pump so if I lose oil pressure the fuel pump will quit. No more leaking. If anybody is interested I have an extra later model adapter. I don't know why I bought two of them. I have already soaked it in carb cleaner. If anybody wants it I would let it go for what I paid for it which I thing was about $40 plus shipping. I would even make you a new gasket.
Glenn
Dextron 111 or later is the go to ATF for the Slim Jim or Jetaway. I'm not sure you can find Dextron 111 any more but any of the later Dextron numbered products are all compatible with each other and work the same..... Tedd
Picked up a good used bumper, paid $500 and it has a big dent in it that seller "forgot about". Did not show in pictures he sent. Hour and fifteen minute drive.
Yep, those indentations were for the chrome exhaust tips. The exhaust pipes never did actually come out of those tips by the way. They were just ornamental.
A good chrome shop could probably take out much of that dent. It would really **** me off to drive that many miles and find out that the bumper was dented that bad..... Tedd
Thanks for reply's, now have to find some of the exhaust tips. Was trying to figure out how they would have run the exhaust to them, especially on the pass side.
Is your car setup for duels? I've never had a 56 so this is speculation but maybe a regular 88 isn't cut for the left hand side exhaust to go through the frame and exit down the frame rail. Though I can't imagine Oldsmobile not cutting all the frames the same..... Just a thought.... Tedd
Ted, will look for holes thru frame on drivers side next time it's on lift. Mine is just single on pass side. When I get ready to tear apart the 56 98 I will check that frame too, but I believe they came with duals.
Chris, if you go up there^^^ to "search" and type in 1956 Dual Exhaust you will find several educational threads on the subject.
Chris: In your post of January 1st, you referenced that you removed the oil filter and the return hose was plugged-up. What is the return hose?
Yes, it was a remote oil filter that was mounted on the passenger inner fender. One line was hooked to stock oil filter housing and the other to a small port on front of block by water pump. Both lines were plugged with sludge.
