54 , 88 Manual Brakes
Old Mar 17, 2019 | 06:04 PM
johnreb49's Avatar
Are there any tricks or tips anyone has on master cylinder replacement and lines ?
Also what's the trick to filling the cylinder and what type of fluid is recommended ?
Old Mar 19, 2019 | 12:07 AM
mpolds's Avatar
I have the Master Cylinder BRAND NEW, No Core Required.
The steel lines you can buy from a parts store -- and bend them yourself -- or buy them from
those outfits that custom bend them, though more expensive. Can advise.
Always best to simply call me -- Craig -- 516 - 485 - 1935...
Old Mar 19, 2019 | 02:54 AM
Ozzie's Avatar
The Oldsmobile shop manual calls for G.M. Brake Fluid number 11. I use DOT 4 in mine. I fill it using a mirror and syringe.
Old Mar 19, 2019 | 06:44 AM
classicmuscle442's Avatar
Just rebuilt mine on my 56, Buick master cylinder rebuild kit thru Rock Auto. Used Ni-comp brake lines and can fill with smaller brake fluid bottle.
Old Mar 19, 2019 | 12:10 PM
mpolds's Avatar
A 1956 BUICK Master Cylinder ----- looks N O T H I N G --- like this --- that is a one - year, all by itself, UNIT....
Old Mar 19, 2019 | 05:37 PM
Never said it looked like it, same rebuild kit. Mobileparts here to help or sell parts?
Old Mar 20, 2019 | 06:18 AM
johnreb49's Avatar
I am most likely going to rebuild this pump and replace the lines .
The springs and shoes look healthy inside the drum..
Old Apr 16, 2019 | 11:26 AM
DFitz's Avatar
74 2.8L Capri
John,
Depending on the state of your carpet around the brake pedal, there is a removable plate in the floor. Take the plate off, and filling the master cylinder becomes easy. Of course I discovered this after I built a custom top for the master with a nipple on top using the vent to fill it with a syringe.
OldsmobileKid
Brakes/Hydraulic Systems
Apr 7, 2015 04:50 PM
DFitz
Aug 28, 2013 07:05 PM
veltboy618
Jul 14, 2011 07:10 PM
Joeypete
Jan 20, 2010 07:09 AM
68conv455
Sep 16, 2008 10:49 AM
