1950 Oldsmobile - Oil filter adapter OFA-1 detailed instructions
Old May 21st, 2021, 10:18 AM
jeff.tennis's Avatar
Recently purchased an oil filter adapter (OFA-1) for my 1950 Oldsmobile 88 and attached the instructions (p. 1-5).
jeff.tennis is offline
Old May 21st, 2021, 10:21 AM
Curious, does anyone have any additional installation photos?
Appreciate everyone's time and any feedback
Old May 22nd, 2021, 07:39 AM
Tedd Thompson's Avatar
I'm still running the canister on mine but have installed on other cars filter adapters off of 394 Old's which look exactly like what you have. When you remove your old filter holder look how it is put together should be pretty self explanatory as they are mostly the same with the adapter changing at the canister flange for the twist off filter..
Note.. some aftermarket adapters have been known to seep some from poor machined surfaces make sure everything is especially clean and flat and use a little RTV on block to adapter even though there is a gasket..... Tedd
Tedd Thompson is offline
Old May 22nd, 2021, 09:47 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I had one of these on my 54 and it started leaking like crazy. I replaced it with an adapter from a 394 which took a spin on filter from the factory. Here is one on ebay.
1963-1964 OLDSMOBILE 394 V8 OIL FILTER ADAPTER AC PF-7 5573321 STARFIRE JETFIRE | eBay
redoldsman is online now
Old May 22nd, 2021, 11:33 PM
Ozzie's Avatar
Thanks for the information. I will try it on my '55.
Ozzie is offline
Old May 23rd, 2021, 10:38 AM
redoldsman's Avatar
I don't think you will be sorry. It has the provision where your oil pressure gauge hooks up. I have an electric fuel pump on my 54 so I added fittings for a cutoff oil pressure switch for the fuel pump. You will have to make a gasket which is pretty easy. Let us know how it works out.
jeff.tennis
January 7th, 2023 12:33 AM
Bfg
November 15th, 2020 04:29 PM
Rocketbrian
March 3rd, 2020 05:18 PM
Powermat
July 19th, 2017 12:32 AM
bulldog
March 6th, 2013 03:20 PM
Quick Reply: 1950 Oldsmobile - Oil filter adapter OFA-1 detailed instructions
