1950 Olds with 1955 Olds transmission
Old Feb 7, 2022 | 01:21 PM
carnutz's Avatar
I need some help. Hopefully someone has been down this road before and has come up with a solution. The range of motion on my shift lever sticking out of the steering column does not allow me to get a 'good' neutral and a 'good' reverse at the same adjustment. I can get a 'good' neutral, so the body does not surge forward on starting, but the reverse is marginal and usually pops out after a few feet. I can hold it in reverse manually, but it's a PITA. Also, I can adjust the linkage so the reverse is solid, but the car starts in drive.
It seems that the range of motion of the shift lever needs to be longer with the '55 trans as opposed to the '50 trans.
Anyone have this problem before? Any help would be appreciated.
Thanks,
Old Feb 7, 2022 | 06:24 PM
carnutz's Avatar
Coldwar, the column in the '50 Olds is original. I've filed the opening in the collar where the shift lever protrudes and it help a little, but now in the neutral the shift arm touches the head. I've increased the range of motion, but it is still not enough. The lever on the '55 trans is a short stubby piece and I have not come up with a way to shorten it further. I don't know if the steering column on a '55 is different than a '50. I've looked online and cannot find an exploded view of either column.
I was hoping that someone had been down this road and came up with a solution.
Old Feb 8, 2022 | 08:03 AM
2blu442's Avatar
Welcome to the site carnutz. I'm also in Medford Oregon. I have a 1955 Olds 98 parts car but it has a 1959-60 engine/transmission in it. I do have the linkage from another car, a 1954 Olds 88 with the 324. Your welcome to come by and look at the linkage to see how its setup if that would help. John
Old Feb 8, 2022 | 08:46 AM
Tedd Thompson's Avatar
John, the 54 and the 55 should be the same. Carnutz. Have you tried adjusting the long rod from carb linkage to transmission, or is that the adjustment you are talking about? It's very sedative, and a little goes a long way. I've never put a 324 on an early transmission, so I'm just guessing....Tedd
Old Feb 8, 2022 | 10:38 AM
carnutz's Avatar
John, I'm in California for a couple of months and won't be home until early April. Is it possible to take a photo of the arm sticking out of the steering column and post it or email it to me?
Thanks,
Larry
Old Feb 8, 2022 | 10:50 AM
2blu442's Avatar
Yes, I can take some pictures and post them here or send them to you in an email. Whichever you prefer.
Old Feb 8, 2022 | 11:00 AM
rocketraider's Avatar
Oldsdruid
50 HydraMatic is N DR LO R. 55 trans is N DR S LO R. In other words you have an extra shift selector position that the 1950 column isn't set up to accommodate.
I expect you'll have to rework something inside the 50 column to make this work, unless a 52-55 column will bolt into your 50.
Old Feb 8, 2022 | 02:18 PM
carnutz's Avatar
Rocketraider, I suspect you are right and the solution to my problem is in the steering column. Does anyone have an exploded view of the '50 column or better yet a spare column lying around?
Old Feb 8, 2022 | 07:25 PM
Charlie Jones's Avatar
Phantom Phixer
This is 1949, but should be typical of 1950.
Old Feb 8, 2022 | 07:33 PM
carnutz's Avatar
Charlie, thanks, but I need the portion of the steering column in the engine bay.
aqua67w30
Jul 24, 2021 07:37 AM
My2nd 69 442
Nov 18, 2018 02:41 PM
Olds Scott
May 22, 2017 09:27 AM
1971viking
May 14, 2012 07:57 AM
msco123
Sep 8, 2010 06:09 PM
