1948 model 60 steering column lubrication
Old April 16th, 2015, 07:26 PM
bobmobile's Avatar
Does anyone out there know how to lubricate the steering column? Mine seems to be binding. Thanks
bobmobile is offline
Old April 17th, 2015, 05:37 AM
twintracks's Avatar
There is probably a bearing at the top of the shaft, beneath the steering wheel. Other than that, I don't think there is a place that can bind. It should be just a shaft inside a tube on down to the steering box. The steering shaft is just an extension of the steering box.
twintracks is offline
Old April 18th, 2015, 04:32 AM
bobmobile's Avatar
Thanks for the advice. Perhaps then it is the king pins. I've had trouble lubing these. The grease just doesn't want to flow into the joint on one side, even after freeing the ball in the zerk fitting. The car was sitting idle before I got it. Guess I need to get new fittings. I dont want to dismantle the king pins as they seem in good order.
Old April 18th, 2015, 08:51 AM
twintracks's Avatar
It might free up with use, but you definitely want to get some grease everywhere it's needed.
Fun with original cars...
leroycjr
20
January 10th, 2018 03:48 PM
bobmobile
July 7th, 2014 04:55 PM
The_German
July 3rd, 2013 08:09 AM
nj_cutlass72
March 4th, 2012 08:53 AM
Donaldo7
October 11th, 2011 05:40 AM
Quick Reply: 1948 model 60 steering column lubrication
