1948 model 60 steering column lubrication
Old Apr 16, 2015 | 07:26 PM
bobmobile's Avatar
Does anyone out there know how to lubricate the steering column? Mine seems to be binding. Thanks
Old Apr 17, 2015 | 05:37 AM
twintracks's Avatar
There is probably a bearing at the top of the shaft, beneath the steering wheel. Other than that, I don't think there is a place that can bind. It should be just a shaft inside a tube on down to the steering box. The steering shaft is just an extension of the steering box.
Old Apr 18, 2015 | 04:32 AM
bobmobile's Avatar
Thanks for the advice. Perhaps then it is the king pins. I've had trouble lubing these. The grease just doesn't want to flow into the joint on one side, even after freeing the ball in the zerk fitting. The car was sitting idle before I got it. Guess I need to get new fittings. I dont want to dismantle the king pins as they seem in good order.
Old Apr 18, 2015 | 08:51 AM
twintracks's Avatar
It might free up with use, but you definitely want to get some grease everywhere it's needed.
Fun with original cars...
leroycjr
20
Jan 10, 2018 03:48 PM
bobmobile
Jul 7, 2014 04:55 PM
The_German
Jul 3, 2013 08:09 AM
nj_cutlass72
Mar 4, 2012 08:53 AM
Donaldo7
Oct 11, 2011 05:40 AM
