1948 6 Volt Issues
Chase it all wires with a multi-miter and see where the juice stops or if it is even starting. Check all the grounds if you haven't done so, also the bulb holders for corrosion even though it looks good. I've been where you are not too long ago, turned out to be the ground on the tail light bezels even though they were tight....Tedd
No because it's a separate circuit, the taillights come on via headlight switch, you can assume the ground side is ok though. The brake and directionals are routed through the directional switch. What you need to do is first check the bulb to ensure both filaments are intact, and second check for voltage at the socket with the brake pedal depressed and then with the directional selected with the key on.
If it were a ground issue the taillights would not work either.
Have you checked the voltages or inspected the bulb?
So here is the latest......
I had 2 factory wires on the passenger side rear. I thought one was for brake and one was for running and turn.
However I found a 3rd (Newer wire) that was back there and it was for my turn. I ended up connecting it to the factory wire and all lights now work.
I think it was added when the previous owner added the turn signal lever.
I put in new 6V bulbs and they all work. Not 100% sure what I did, however they work.
NOW - New issue.
Front parking lights. Passenger side does not work, however does work when turn signal is on.
It's a single wire as well......
I need to walk away for a while.
Positive Ground.
NOW - New issue.
Positive Ground.
Tail and turn signal lights
Put a little silicone grease in the bulb sockets and bulb bases in big and little bulbs.
This prevents rust and corrosion which prevents light issues. As they use to say - a little dab will do you.
A NEW battery post cleaner can be used to clean corroded contacts and inner shell for big bulbs.
Also use grease on headlight connection parts to help prevent dim lights.
You can carefully disassemble and clean the headlights switch then grease and reassemble.
This works over a large number years and venders before and after 1948.
Ron
Ron
I think I see what's going on here.
Not all 1948 Oldsmobiles were equipped with turn signals from the factory. In fact, they did not become standard until 1952.
Turn signals were an option, and offered as a dealer installation package as early as 1941.
Various aftermarket turn signal switch kits were also offered.
Does the turn signal switch clamp on to the column? Or is it built in?
BTW the system is not positive ground. Positive ground was only found in some Fords and Mopar's.
Generally, or quite often, if a non activated light comes on when something else is turned on you have a bad ground back feeding to that light.... You still need to run the wires in question with a multi meter... Tedd
Yes - The turn signal switch mounts to the steering column. Looks NON-OEM.
It's odd to me that I have a parking lamp that works and a turn signal that does not from the same socket with only 1 wire going to it.
Maybe the headlight switch is taking a dump?
