1948 6 Volt Issues
Old Jun 27, 2022 | 04:45 AM
57J2Olds's Avatar
1948 6 Volt Issues
Hello,
Trying to get all my lights working on the 48. I still have the 6 volt system. Do I need 6 volt bulbs for parking and tail/brake lights?
Old Jun 27, 2022 | 05:56 AM
Yes
Old Jun 27, 2022 | 05:21 PM
Tedd Thompson's Avatar
And everything else that is wire to the 6 volt system. Tedd
Old Jun 28, 2022 | 06:22 AM
57J2Olds's Avatar
For the life of me I cannot figure out why I have taillights both LH/RH.
Turn signals and brake light drivers side, however no turn signal or brake on passenger side.
Driving me nutzzzzzz
Old Jun 28, 2022 | 07:46 AM
Chase it all wires with a multi-miter and see where the juice stops or if it is even starting. Check all the grounds if you haven't done so, also the bulb holders for corrosion even though it looks good. I've been where you are not too long ago, turned out to be the ground on the tail light bezels even though they were tight....Tedd
Old Jun 28, 2022 | 08:11 AM
The taillight lamps have 2 filaments, one for the taillights and one for brake and directionals. Sounds like you have a bad bulb or a bad connection for the second filament.
Old Jun 28, 2022 | 09:15 AM
57J2Olds's Avatar
If I have tail lights then can I assume I have full power to that bulb socket?
Old Jun 28, 2022 | 09:29 AM
No because it's a separate circuit, the taillights come on via headlight switch, you can assume the ground side is ok though. The brake and directionals are routed through the directional switch. What you need to do is first check the bulb to ensure both filaments are intact, and second check for voltage at the socket with the brake pedal depressed and then with the directional selected with the key on.
Old Jun 28, 2022 | 09:54 AM
57J2Olds's Avatar
I failed to mention that the Drivers Side front signal works......just not the rear......
Old Jun 28, 2022 | 10:12 AM
Sugar Bear's Avatar
Rule out a bad filament in a two filament bulb by putting a bulb that is known to be good (not just new) in the socket that doesn't work properly.
Good luck!!!
Old Jun 29, 2022 | 09:19 AM
BobsFiftyEight's Avatar
Tool Freek
Most of the time is a poor ground issue.
Bob
Old Jun 29, 2022 | 09:26 AM
57J2Olds's Avatar
I spent way too much time on it yesterday. Even thought of selling it.
My 6 volt bulbs will be here today. One last chance....
Old Jun 29, 2022 | 09:51 AM
Sugar Bear's Avatar
You'll never be able to sell it with lights that don't work! Walk away, take a break it's supposed to be a hobby/fun.
Good luck!!!
Old Jun 29, 2022 | 10:01 AM
Bob
If it were a ground issue the taillights would not work either.
Have you checked the voltages or inspected the bulb?
Old Jun 29, 2022 | 10:29 AM
57J2Olds's Avatar
I have new 6 volt bulbs arriving today.
Old Jun 29, 2022 | 10:30 AM
57J2Olds's Avatar
This is what I'm working on......
Old Jun 29, 2022 | 12:18 PM
Sugar Bear's Avatar
Looks original and all there.
Old Jun 29, 2022 | 12:47 PM
57J2Olds's Avatar
Thanks....just waiting for the mailman......6 v bulbs are in his truck,,,,
Old Jun 29, 2022 | 01:03 PM
Sugar Bear's Avatar
Must be an old mail truck then...
Old Jun 29, 2022 | 01:04 PM
Sugar Bear's Avatar
Is the Oldsmobile positive ground?
Old Jun 29, 2022 | 02:35 PM
57J2Olds's Avatar
So here is the latest......
I had 2 factory wires on the passenger side rear. I thought one was for brake and one was for running and turn.
However I found a 3rd (Newer wire) that was back there and it was for my turn. I ended up connecting it to the factory wire and all lights now work.
I think it was added when the previous owner added the turn signal lever.
I put in new 6V bulbs and they all work. Not 100% sure what I did, however they work.
NOW - New issue.
Front parking lights. Passenger side does not work, however does work when turn signal is on.
It's a single wire as well......
I need to walk away for a while.
Positive Ground.
Old Jul 1, 2022 | 09:32 PM
Love1955oldsmobile's Avatar
Tail and turn signal lights
Put a little silicone grease in the bulb sockets and bulb bases in big and little bulbs.
This prevents rust and corrosion which prevents light issues. As they use to say - a little dab will do you.
A NEW battery post cleaner can be used to clean corroded contacts and inner shell for big bulbs.
Also use grease on headlight connection parts to help prevent dim lights.
You can carefully disassemble and clean the headlights switch then grease and reassemble.
This works over a large number years and venders before and after 1948.
Ron
Old Jul 2, 2022 | 08:50 AM
Charlie Jones's Avatar
Phantom Phixer
I think I see what's going on here.
Not all 1948 Oldsmobiles were equipped with turn signals from the factory. In fact, they did not become standard until 1952.
Turn signals were an option, and offered as a dealer installation package as early as 1941.
Various aftermarket turn signal switch kits were also offered.
Does the turn signal switch clamp on to the column? Or is it built in?
BTW the system is not positive ground. Positive ground was only found in some Fords and Mopar's.
Old Jul 2, 2022 | 06:13 PM
Generally, or quite often, if a non activated light comes on when something else is turned on you have a bad ground back feeding to that light.... You still need to run the wires in question with a multi meter... Tedd
Old Jul 2, 2022 | 07:47 PM
Sugar Bear's Avatar
^^^^^^^^^^^^Agree
Old Jul 5, 2022 | 11:15 AM
57J2Olds's Avatar
Yes - The turn signal switch mounts to the steering column. Looks NON-OEM.
It's odd to me that I have a parking lamp that works and a turn signal that does not from the same socket with only 1 wire going to it.
Maybe the headlight switch is taking a dump?
Old Jul 5, 2022 | 02:21 PM
This may be close to how it's wired up for single filament front lamps. Disregard the ammeter as it may be getting power somewhere else.
Old Jul 5, 2022 | 06:36 PM
Funkwagon455's Avatar
Bob
X2, double and triple check!!
Old Jul 5, 2022 | 08:08 PM
Sugar Bear's Avatar
Try running a ground directly to the body of the turn signal switch. My friend just had a similar problem with an aftermarket turn signal switch, the added ground made it work.
Good luck!!!
Old Jul 6, 2022 | 07:17 AM
57J2Olds's Avatar
Good luck!!!
Thanks...I'll try it tonight.
57J2Olds
Sep 5, 2021 01:19 PM
roye182000
May 28, 2020 12:20 PM
73aussie455
Sep 23, 2014 04:10 AM
jr's67
Sep 13, 2010 06:13 AM
Sid
Sep 10, 2010 02:33 AM
