1941 Olds - Parts needed.
Old Apr 6, 2022 | 02:56 AM
KrisKringle's Avatar
Hello from Germany,
I am working on a 1941 Olds 6 with an automatic transmission. The car needs the following:
  1. Cylinderhead gasket. (I found a replacement head on Ebay)
  2. Radiator cap
  3. Transmission mounts (I contacted Fusick, but there are none in stock, and sending the ones on the car away for repair is not possible.)
  4. Upper motor mount
  5. Temperature sender
  6. Fan belt.
Thanks in advance for any help,
Jonathan.
Old Apr 6, 2022 | 05:34 AM
Wilkommen bei unser Site.
You might be able to get the head gasket from Egge:
https://egge.com/
Have you checked Kanter for parts:
https://www.kanter.com/index.aspx?gc...SAAEgJZC_D_BwE
Old Apr 6, 2022 | 10:34 AM
https://egge.com/
Thanks for the information. I checked out Kanter in the first round. They need an exchange for the mounts, but I will look again for the other parts. At the time, I was only looking for the mounts.
Old Apr 24, 2022 | 07:29 PM
Doctor's Olds's Avatar
Hi. I own a 41 Olds and got my temperature sensor from Kurt Kelsey, in Iowa. See his add on the early times Pontiac newsletter below. He is a big early Pontiacs man and told me Oldsmobile use the same sensor and indeed it fit mine perfectly well. My car is an 8 cylinder and I don't know if it may be different for your 6 cylinder engine. Good luck!
Old Apr 29, 2022 | 02:15 PM
35olds's Avatar
Here's a place that has at least 1 rear & 1 front upper engine mount
https://ocpnw.com/oldsmobile-1939-48...1-made-in-usa/
​​​​​​https://ocpnw.com/oldsmobile-1937-19...3-made-in-usa/
Old May 25, 2023 | 12:01 AM
Thanks for the information. I will email him.
Old May 25, 2023 | 12:17 AM
1941 Olds Fan Belt needed.
Hello again from Germany.
Thanks to all for your help with my last query. I found the engine mounts on eBay, and the temperature sender locally.
I am looking for the correct fan belt. The 7575 XL available from Kanter (or Rock Auto) is not the correct one.
Is the Gates 44553, or the Dayco 28473 the correct one for a 1941 Olds with the straight six?
Thanks in advance for your help.
Jonathan.
Old May 25, 2023 | 05:46 AM
35olds's Avatar
The aftermarket number for the fan belt was originally V101. You'll still find it difficult to bring that number up on most websites but if you strike out then perhaps try this place. https://au-vbeltguys.glopalstore.com...13540bfd&_ss=r
Old May 26, 2023 | 01:05 PM
Thanks, everyone. I found the correct belt, ACDELCO T28473 on Rock Auto. 1937 Pontiac, belt drive is where it can be found.
cobalt
Sep 21, 2015 07:24 AM
cobalt
Sep 30, 2013 09:09 AM
J-(Chicago)
Feb 9, 2012 02:17 PM
zed
Aug 16, 2009 07:33 PM
BosMobile
Jul 17, 2009 07:52 AM
