1932 Olds Info and VIN location
Old Jan 17, 2019 | 08:21 AM
Cweber74's Avatar
I just recently purchased a 32 Oldsmobile coupe off of an aunt and uncle that have owned it since 66. I’m trying to find some more information on it. I received a clean title in their name but I haven’t found the vin or serial number on the car anywhere. There’s a thin metal tag on the firewall with a 3 didgit body number but that’s all I’ve found. Thanks for any help.
Old Jan 17, 2019 | 08:49 AM
47 Convertible's Avatar
Some Chevrolets of about the same vintage had an aluminum tag screwed to the floor on the passenger side next to battery box opening. Not sure if other GM cars did the same. Couldn't tell from your photo is your 32 has floorboards in it. Some makes used the number stamped on the engine block as an ID but that looks like a dead end for you if the original engine is gone.
If all else fails your state may have a process for assigning a "VIN".
Is there an identification number printed on the title? If your paper work has some kind of vehicle ID on it, check with vehicle bureau or state police to see if you can stamp the same number on your car and where on the car they specify.
Old Jan 17, 2019 | 08:57 AM
Cweber74's Avatar
No there’s no floor boards either. The tag on the firewall has a body number stamped but it’s just a 3 digit number...197. The vin in my title has a longer number number. It’s a good title so I guess it doesn’t matter too much but if I were to ever get pulled over or need to show a matching number on the car I wouldn’t be able to. Unless there’s something stamped somewhere else.
Old Jan 18, 2019 | 12:01 PM
Russ P in MD's Avatar
Here's an old thread where a forum member "blucar" mentioned the location of the tags on a 1936 car, based on info from a reference book he had. Maybe try to contact him and see if he can tell you what the book shows for a 32?
https://classicoldsmobile.com/forums...936-coupe.html
According to this site, it's a plate on the floor front passenger side. See the bottom right VIN/ID section of the form:
http://www.classiccardatabase.com/specs.php?series=284&year=1932&model=15768
If the VIN number on the title has a lot of digits, it may be a replacement VIN number from the DMV. In that case, maybe ask your aunt or uncle if they recall this or have the loose tag?
Old Sep 26, 2019 | 07:50 PM
Russ Golesh's Avatar
Look on top of left front frame rail. It should be stamped "OMW" with an alpha numeric VIN following. These preceded actual VIN's and were known as serial numbers.
Don Bunnell
May 8, 2020 02:15 PM
TheFarens
Oct 10, 2016 11:08 AM
roberer
Jun 14, 2014 08:19 PM
olds53rocket
Dec 22, 2006 05:46 PM
