70 driveshaft cutlass supreme
I bought a 70 cutlass , that is torn down to shell, the drive shaft that came with car looks to be two pieces, rubber inside! does this drive shaft slide inside one another? I put it in car and it slides 3 inches inside trans put just clears rear pinion , only has about 3/4 inch play to slide in and out trans! I think it should move more then that. not much room for up and down travel of rear axel.
Thanks, good news to me, that's the only driveshaft I got with car. I had many GTO's and Skylarks, and they all had a lot of room for movement, I was worried . If anyone else thinks different , let me know.
costpenn
April 11th, 2012 07:25 PM
TRW
January 21st, 2011 05:38 AM
