Transmission cooling lines with headers
Old Apr 12, 2024 | 05:54 AM
rfpowerdude's Avatar
What have people done for transmission cooling lines when using headers? 1970 Cutlass S with TH350. It looks like the transmission lines would normally go outside of the exhaust manifold on the frame, whereas with exhaust headers, the header is in the way. Maybe just hand bend them into submission? I have new replacement lines that would work perfectly with exhaust manifolds. Headers, not so much.
Old Apr 12, 2024 | 06:01 AM
I had some hydraulic hoses made to run then up and over the inner fender along side the heater hoses.
Old Apr 12, 2024 | 06:06 AM
Yes, it seems that flexible hoses would be a great way to make custom routing for the lines. Since they are not under a lot of pressure, almost anything would be better than hard lines all the way back. Maybe some –6 AN to hardline adapters and braided lines might be nice.
Old Apr 12, 2024 | 06:11 AM
This is what I did.
Old Apr 12, 2024 | 06:17 AM
Very nice! Mine is factory AC so I will have to come up with a routing scheme.
Old Apr 12, 2024 | 06:54 AM
4speed455's Avatar
I used lines for a 72 on my 70 and made a few bends to move them out of the way of the headers and the suspension. The 72 radiator has the top line port much lower then the 70, this helped keep the lines up out of the way.
https://classicoldsmobile.com/forums...cement-166624/
Old Apr 12, 2024 | 08:29 AM
^^^This. I've never had a problem that a few minor tweaks didn't resolve. I'm not a fan of rubber or AN lines for trans cooling.
Old Apr 12, 2024 | 09:00 AM
Mine have been on there since 2011 with no issues. Most aux trans coolers use rubber lines.
Old Apr 12, 2024 | 09:07 AM
Lots of aftermarket parts take the easy way out. When you are selling a one-size-fits-all cooler, it's kind of difficult to provide pre-bent hard lines. That doesn't mean it's the best answer. The factory RPO M55 aux trans cooler used hard lines. I find hard lines much easier to route, cleaner looking, and definitely less prone to damage.
Old Apr 12, 2024 | 09:32 AM
cdrod's Avatar
Rodney
I made and flared my own lines for my '72 442 convertible project. I wrapped both lines in heat shrink tubing followed by an outer layer of heat shield material where they pass close to the header tubes.
Rodney
Old Apr 12, 2024 | 12:23 PM
bccan's Avatar
I ran them along the oil pan rail. 1 or 2 clamps using pan bolts, out the front and to the radiator. They’re visible under regulator, heading past idler arm and past the lower rad hose drain clamp jungle..
Old Apr 12, 2024 | 01:17 PM
On my 70 and 71 (both with 350s and AC), I simply bent the factory lines as needed to clear the headers.
Dpj54
Nov 16, 2020 06:35 AM
Fletchmo72
Jul 26, 2018 04:49 PM
my71olds
Jul 13, 2017 09:57 PM
ralsy
Jan 5, 2011 05:10 PM
GothamCity
Oct 25, 2007 06:10 PM
